Author Topic: Yet another grounding question  (Read 1653 times)
marvin_rock
  • Last login:December 29, 2013, 06:55:51 pm
« on: December 23, 2013, 07:31:00 pm »
So I'm re-doing all my cabling.  I didn't like the messiness with the cables that came with my buttons, I'm a bit OCD like that.
Here's what I have for my regular switches -
Mostly pay attention to the yellow/blue buttons setup.
As far as the grounding goes, can I do something similar and just have a single ground cable come from one side of the board, and a single ground come from the other side, join them up and put them into the single ground connector?  Or do I have to have one single cable hop between 32 different ground connections?
I can attempt to explain better if needed.
Louis Tully
Re: Yet another grounding question
« Reply #1 on: December 23, 2013, 07:39:02 pm »
« Last Edit: February 12, 2015, 04:09:21 pm by Louis Tully »
marvin_rock
« Reply #2 on: December 23, 2013, 08:31:36 pm »
Close - but here's a shoddy diagram of what I'm HOPING I can do, the image you posted shows them 100% daisy chained, which I'd like to avoid if possible.  Here's what I'd like to do (attached)
Louis Tully
« Reply #3 on: December 23, 2013, 09:04:35 pm »
« Last Edit: February 12, 2015, 04:09:25 pm by Louis Tully »
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #4 on: December 24, 2013, 07:01:25 am »
Easy to remember saying...."Ground is ground all around"
As long as they are all tied together in some form, you are good to go.
marvin_rock
« Reply #5 on: December 24, 2013, 07:33:53 am »
That's what I figured, but I had a hard time finding any images of anything that WASN'T daisy-chained, I was concerned it would cause some weird issue.
I'm hoping to get my hands on a soldering iron and some solder today to finish this off over my currently nothing-to-do holiday break =D
