Author Topic: killer instinct issue  (Read 1378 times)
trendy21
  • Last login:January 27, 2023, 08:11:48 am
  • Alright, Alright, Alright
« on: December 20, 2013, 02:10:27 pm »
hello i downloaded new mame 151 and rom set and cant get killer instinct working no matter what i try i have the chd in a folder it worked before i upgraded from version 127, hopefully someone is having same issue, thanks
  • Last login:Yesterday at 07:04:36 pm
Re: killer instinct issue
« Reply #1 on: December 20, 2013, 02:43:33 pm »
IIRC CHD formats changed around 146.
You'll need to get the new version CHD.
trendy21
« Reply #2 on: December 20, 2013, 03:03:17 pm »
i have the new chd from version 150 if its the same as 151 it should still work right? i tried from several places with same result. would clrmame pro fix this parent rom and chd diff? or better direct me
« Last Edit: December 20, 2013, 03:05:06 pm by trendy21 »
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
« Reply #3 on: December 21, 2013, 11:41:00 am »
If you played it with the older version - MAME likely created a file which now is a version mismatch to the current CHD.  Check in your "DIFF" folder and delete the kinst.diff file in order to correct the mismatch and let MAME create one appropriate to the newer CHD.
trendy21
« Reply #4 on: December 21, 2013, 02:35:12 pm »
that worked thanks a lot
