Author Topic: MAME ROMS gone wonky? (A Tapper Tragedy)  (Read 9812 times)
Kit444
  • Last login:May 26, 2015, 04:15:47 pm
« on: December 18, 2013, 09:14:34 am »
Do ROMS ever go haywire? I'm using .148. Tapper previously worked. I play tested and configured it. Now that I have my cabinet up and running, I can't get it to load either in Mala or directly from MAME. Any ideas what may have happened? I haven't changed any configurations in MAME.
Re: MAME ROMS gone wonky? (A Tapper Tragedy)
« Reply #1 on: December 18, 2013, 09:29:40 am »
Are you using the same revision of MAME and the same roms as when it was working before?
Is MAME giving you the message that files are missing, or is it just not working?
Does the folder it is in contain ALL the roms that were present when tapper was working before?
EDIT: - 0.145u7: Moved Sound Board prom 5784 to midssio device set.
So you need to have the midssio.zip rom present if using a version of mame newer than v.145
« Last Edit: December 18, 2013, 09:42:28 am by BadMouth »
JDFan
« Reply #2 on: December 18, 2013, 10:13:51 am »
^This - it uses the midway SSIO soundboard so you need to make sure you have the midssio.zip file in your rom folder. I just recently went through the same thing !
Kit444
« Reply #3 on: December 18, 2013, 11:34:05 am »
It's the same configuration as what worked before. MAME is telling me files are missing, so I'll check for that sound board file. Thanks!
Kit444
« Reply #4 on: December 18, 2013, 11:37:08 am »
As a follow up, how many games could that be affecting? I wonder if there are other dysfunctional roms I gave up on that could be revived.
« Reply #5 on: December 18, 2013, 11:56:55 am »
These roms use the same source driver as Tapper, so could possibly be affected by the missing midssio
demoderb
dotrone
dotron
dotrona
domino
dpoker
journey
kickc
kick
kickman
kroozr
nflfoot
shollow
shollow2
solarfox
tapper
tappera
rbtapper
sutapper
timber
tron4
tron3
tron2
tron
twotiger
twotigerc
wacko
List generated using Mawler.
(see thread stickied in software forum if interested in checking it out)
Kit444
« Reply #6 on: December 18, 2013, 11:58:58 am »
Thanks for the list. I have a few of those on my cab so I'll test them again.
« Reply #7 on: December 18, 2013, 12:01:32 pm »
Lots of games also require bios files, such as neogeo.zip
No Neo Geo game will work without it.
List of all bios roms (not all these systems are fully emulated):
3dobios
acpsx
aleck64
allied
alg_bios
ar_bios
mk6nsw11
aristmk6
atpsx
atarisy1
atluspsx
awbios
konamigv
bubsys
cd32bios
cdibios
chihiro
crysbios
decocass
galgbios
hikaru
hng64
isgsm
pyson
kviper
maxaflex
megaplay
megatech
aristmk5
gp_110
v4bios
mac2bios
macsbios
naomi2
airlbios
naomi
f355bios
naomigd
hod2bios
neogeo
nss
pgm
playch10
psarc95
sammymdl
shtzone
stvbios
su2000
sfcbox
skns
gts1
gts1s
sys246
sys256
sys573
konamigx
taitofx1
taitogn
tourvis
tps
triforce
gq863
taitotz
vspsx
cpzn1
cpzn2
Kit444
« Reply #8 on: December 18, 2013, 07:56:17 pm »
Adding midssio.zip did the trick.  Thanks for the help!
Haze
    • MAME Development Blog
« Reply #9 on: December 18, 2013, 10:12:45 pm »
3dobios
acpsx
aleck64
allied
alg_bios
ar_bios
mk6nsw11
aristmk6
atpsx
.. snip
this list is rather outdated.
the problem here wasn't a missing bios, but instead a missing DEVICE rom "midssio"
These are like bios roms, but aren't, they typically represent common internal roms of devices, or standard boards used by manufacturers.  As a result your list here didn't even cover the "midssio" case that was actually the issue here.
Would probably help to list all those as well, because as far as an end user is concerned they may as well be additional bios roms, and they're only likely to increase in numbers as common chips get decapped, or ROM data is better organized and moved to the correct places, eg. the ym2608 change I made ;-)
(yeah, I know it's a bit of a pain, but it's part of MAME growing up and becoming more organized / logical from a hardware point of view)
« Last Edit: December 18, 2013, 11:53:03 pm by Haze »
