Author Topic: Missile Command  (Read 4380 times)
jimmer
Missile Command
« on: December 16, 2013, 03:13:23 pm »
Has anyone seen or can point me to a custom Marquee for Missile Command?
I'm looking for something normal shaped, not between speakers.
  • Last login:Today at 05:33:34 am
Re: Missile Command
« Reply #1 on: December 16, 2013, 04:59:41 pm »
Don't see anything print-ready on the usual sites, but you can get some of the art elements here and a large copy of the original marquee on Joymonkey's site here.
If you don't have a subscription to Joymonkey's site, the attached marquee from MameLayPlus might provide a starting point.
You could probably vectorize it using the Vector Magic site.
« Last Edit: December 16, 2013, 05:04:49 pm by PL1 »
jimmer
Re: Missile Command
« Reply #2 on: December 17, 2013, 05:22:45 pm »
Thanks for that, if anyone can get me a high res copy of the marquee I'd appreciate it.
I don't have photoshop skills, but I could probably knock something together in MSpaint.
I'll take a look at  Vector Magic too, as I'm getting quite good at Illustrator tidying up various CPOs that I've used.
I'm not very artistic, but I'm thinking there should be missiles coming up from left and right like in the game, and maybe explosions in the centre, above the Missile Command writing.
  • Last login:February 09, 2026, 11:56:07 am
Re: Missile Command
« Reply #3 on: December 17, 2013, 05:29:33 pm »
I like what Scott posted, to be honest. Simple, retains all the original elements. Good job.
jimmer
Re: Missile Command
« Reply #4 on: December 17, 2013, 05:34:43 pm »
I don't think he was suggesting that as the answer. Just giving me something to trace.
jimmer
Re: Missile Command
« Reply #5 on: December 17, 2013, 05:41:13 pm »
Here is my first attempt.
Who can do better  :)
Re: Missile Command
« Reply #6 on: December 17, 2013, 05:44:33 pm »
Well, if he wasn't, he should have. I hope you're not suggesting to stretch out those elements like that.
+1 for Scott's.
jimmer
Re: Missile Command
« Reply #7 on: December 17, 2013, 05:51:44 pm »
You're a tough customer. I thought you'd like it as I retained all the original elements.
Re: Missile Command
« Reply #8 on: December 17, 2013, 05:54:16 pm »
Well, I own a Missile Command and am a fan of the original marquee. So that's why I probably prefer Scott's.
I mean, not every inch of the marquee needs to be plastered with something.
jimmer
Re: Missile Command
« Reply #9 on: December 17, 2013, 06:34:00 pm »
I'm beginning to like it, so much so I straightened the trails.
Now, how do I goad the good artists into doing better?
jimmer
Re: Missile Command
« Reply #10 on: December 17, 2013, 07:22:45 pm »
My final effort before I get a Hi-Res pic to work with.
jimmer
Re: Missile Command
« Reply #11 on: December 17, 2013, 07:25:00 pm »
And the only example I found on Google.
Re: Missile Command
« Reply #12 on: December 17, 2013, 07:31:20 pm »
At least that one doesn't stretch the elements.
Re: Missile Command
« Reply #13 on: December 17, 2013, 08:47:07 pm »
+1 for Scott's.
Credit where credit's due -- that image is from MameLayPlus.   :notworthy:
I figured that the center section would be a good starting point as long as you maintain the aspect ratio, but I'm not the guy to ask about artistic matters.   :dunno
« Last Edit: December 17, 2013, 08:54:47 pm by PL1 »
Re: Missile Command
« Reply #14 on: December 17, 2013, 09:14:32 pm »
True, but the "lawn dart" interceptors are all over and the placement/orientation of the added elements makes no sense in the context of the game.
In the original, four interceptors are rising from three unseen bases below the marquee and the attacking ICBMs are coming "over the horizon" from the right side -- THAT makes sense and fits with the game.
Re: Missile Command
« Reply #15 on: December 17, 2013, 09:21:24 pm »
I agree. I was just trying to find something nice to say to Jimmer. Your Mamelay example is still the best.
JDFan
Re: Missile Command
« Reply #16 on: December 22, 2013, 12:39:55 pm »
I'd go something Like one of these to avoid the stretching mentioned :
« Last Edit: December 22, 2013, 02:19:06 pm by JDFan »
