Author Topic: Stick Mounted on Metal CP?  (Read 1047 times)
Donkey_Kong
    • CNC Machines
« on: December 13, 2013, 01:59:57 pm »
I have been thinking of trying to build a metal control panel. I had never really considered in the past, and therefore haven't studied it all too much.
Can someone point me to some good examples of sticks mounted to a metal CP?   Would love to see some different methods, ideas, and types of sticks if possible.
Thanks for any help on this.
Re: Stick Mounted on Metal CP?
« Reply #1 on: December 13, 2013, 02:09:44 pm »
The Beast. Vertical Retrace is a good example too.
Donkey_Kong
    • CNC Machines
« Reply #2 on: December 13, 2013, 02:35:22 pm »
Great examples, thank you.
mgb
  • North East, US
« Reply #3 on: December 14, 2013, 01:39:12 am »
There are a couple of ways you can do it.
The easiest way to do it is to just drill through and use carriage bolts. To me, this is very arcade authentic as I don't mind seeing carriage bolts on the cp (some don't like any hardware showing)
For mine though, there were elements of my artwork that I didn't wanna mess up with carriage bolts so I bought pac man joystick mounting plates.
http://www.twistedquarter.com/index.php?main_page=product_info&cPath=190_196&products_id=443&zenid=dlk3joaeh3mqa43q5u7knvr8o5
and had my mechanic weld them in place. because of the step design in the plate, it also gave me a nice little pocket for having my dust washers under the cp which I prefer.
I also didn't want my ball tops to stick up too high so I put a small spacer between each stick and mounting plate.
I also have the little interface board for my spinner and my lighting controller board installed on the underside of my cp. Obviously I didn't want that hardware showing so I epoxied a small half inch thick aspen board on the underside of my cp (the whole underside is sprayed black so it looks clean) and screwed them to that (with spacers)
Just a side note, with a metal cp I was worried about extra noise so I bought rubber gasket material and made rubber gaskets to go between my buttons and the metal cp. I did the same for the joysticks. And I also hot glued the switches on the buttons to keep down rattling.
