Author Topic: ipac config issue  (Read 928 times)
Toadie
  • Last login:December 30, 2013, 09:29:51 pm
ipac config issue
« on: December 12, 2013, 07:37:21 pm »
Well I'm pushing forward on my CP and I have a unique issue that I haven't seen before…
Coin1 seems to be tied to 2B but in the software only ???  Anyone every seen something like this before?
If I unplug one or the other both buttons will light up in the ipac software.  If I reassign them then it doesn't appear to happen.  I'm utterly confused right now.
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
Re: ipac config issue
« Reply #1 on: December 12, 2013, 10:12:34 pm »
Have you tried flashing back to default values?
Hoopz
  • Intellivision Rocks!
« Reply #2 on: December 13, 2013, 10:27:13 am »
Check your grounds?  Not sure that would do it, but I'd definitely rule it out as an issue.
Toadie
« Reply #3 on: December 14, 2013, 03:32:50 pm »
I think I got it, I think I accidentally programmed the board when the settings weren't up to date and then forgot to reprogram it.
