Author Topic: Cheapest PC to JAMMA cabinet option  (Read 1859 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« on: December 06, 2013, 11:35:28 am »
So I want to help my little brother out and put a PC in his Martial Champion cabinet,  I'm not so concerned with having the Martial Champion PCB still playable as it is a pretty ---smurfy--- game and can be emulated without much effort.
What I need is a way to interface the cabinet buttons to the PC and a way to get the VGA signal from the PC on the screen.   I already have a PC setup for hyperspin and a pcb-less JAMMA cabinet.
 I was hoping to avoid a method that uses soft 15khz, preferably I'd like to use a VGA converter that will scale any output to 640X480 interlaced, to avoid the risk of a 60Hz windows bootup screen frying his CRT chassis.
I am eyeing this -> http://www.ebay.com/itm/J-PAC-PCB-USB-VGA-CABLE-INCLUDED-CONNECT-A-PC-TO-YOUR-JAMMA-CABINET-JPAC-/271078768669?pt=UK_Video_Games_Coin_Operated_MJ&hash=item3f1d8dc01d
But will this handle the VGA -> CGA resolution step-down?  Or will I still need soft15KHZ?
« Last Edit: December 06, 2013, 12:02:11 pm by bimm25e »
  • Last login:Today at 07:05:55 am
Re: Cheapest PC to JAMMA cabinet option
« Reply #1 on: December 06, 2013, 12:22:33 pm »
Nope.
mgb
  • North East, US
offset
  • Last login:August 28, 2025, 04:12:09 pm
« Reply #3 on: December 08, 2013, 09:37:15 pm »
I'm using the GBS 8100 converter, not sure differences with GBS 8150, maybe outputs?
Bought mine from here - http://www.jammaboards.com/store/vga-to-cga-pal-ntsc-video-converter-pcb-gbs8100.html
