Author Topic: Coin acceptor on I-pac ve  (Read 1347 times)
steinar-t
  • Last login:April 21, 2019, 02:31:15 pm
« on: November 30, 2013, 09:55:31 am »
Hi!
Working on adding a coin acceptor to my mame cabinet. I manage to make a circuit that triggers a relay when a coin is dropped. Only problem is this coin acceptor i got of a vending machine give a 10ms pulse. This it to short for eiter the i-pac or the relay. If i coud reprogram the CA to give a longer pulse it woud work. Any ideas? I think its a seci RM4 acceptor.
mgb
  • North East, US
« Reply #1 on: November 30, 2013, 10:09:11 am »
The time is programmable but you will need the program and the serial adaptor.
Here's the manual
http://www.aus.at/download/PRORM4GB.pdf
steinar-t
Re: Coin acceptor on I-pac ve
« Reply #2 on: November 30, 2013, 10:35:44 am »
Coud i make the serial adaptor and download the program somewhere? :-\
steinar-t
« Reply #3 on: November 30, 2013, 02:11:34 pm »
I made the circuit looking at the attached schematic. What if i remove everything and just connect ground on i-pac and CS together, an pin 9 on the CS to coin 1 on the i-pac? new schematic also attached. ;)
Edit: Tried this out and it works, but still to fast for the ipac.  A coin that gives 10 pulses only gives 2 credits.  But its close enougt for me to start fitting the coin door and acceptor.
« Last Edit: November 30, 2013, 04:03:44 pm by steinar-t »
