Author Topic: New Product: Pac-Pro™ Leaf-Switch 4-way Joystick  (Read 24047 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
Re: New Product: Pac-Pro™ Leaf-Switch 4-way Joystick
« Reply #40 on: December 18, 2013, 03:36:27 pm »
Just installed mine yesterday.  Love it.  It definately feels like a real pacman stick..and I'm picky as all hell.  It is a little more stiff than I remember, but nothing that takes away from the 4-way experience.  The leaf's make the control feel a lot more responsive, too.
I'm not sure what a grommet would have added since I've never used a leaf stick before..
Overall I'm glad I ordered this stick and will be leaving it my cab, which leaves my reunion stick as a backup :applaud:
Pingaloka
  • Last login:March 30, 2025, 02:11:23 pm
« Reply #41 on: December 29, 2013, 02:50:42 pm »
Just got mine, I have a question. How do I mount the stick? I have a wooden panel. I can't remove the top red ball. Do I have to unmount the whole stick?
chopperthedog
  • Last login:Today at 09:30:46 am
« Reply #42 on: December 29, 2013, 04:08:15 pm »
Google "removing e clip from joystick"
good day.
Xiaou2
  • Last login:Yesterday at 09:49:00 pm
  • NOM NOM NOM
« Reply #43 on: December 29, 2013, 07:57:45 pm »
 Your statements are contradictory.   You say it feels like a real Pacman stick...  then you say your not sure what a grommet would add.    Meaning... you either cant remember what a real pacman stick feels like,  or you have only ever used a generic Reunion stick... or similar Inferior replacement.
 And Yeah..  the reason its Stiff, is because its a Super.  They Stink.  Tore every one off the machines that were in the arcade I managed, and put in Comps immediately.  (to much rejoice)
 They are durable.  But they are ugly, and have a ton of friction to them.  Their typical leaf-micros often get bent and warped, making diagonals a wench to activate.
 The REAL Pacman sticks, use a center pivot grommet.  Unlike a spring pivot, which creates a stick-offset as well as a good deal of resistance to get it going...  A grommet will allow the pivot to remain in perfect center, for faster activation due to less distances traveled.  It also has a uniform resistance, which is pretty light.  Where as a spring based has a range of resistance that multiplies until its surpassed.  That initial surge, or WALL of resistance, is felt every time you have to roll past center.
 In the supers, they use a lot of plastic sleeves, and these sleeves and pivots, are very tight and frictional.  The best thing you could try to do.. is to spray some Formula 21  or other thin lubricant, to help reduce the friction.
 While its nice to have cheap options...  IMO, its far better to have the real deal being reproduced, and have to save up more for it... than to suffer with lackluster compromises.
    • GroovyGameGear.com
« Reply #44 on: December 29, 2013, 10:26:39 pm »
I think very few folks here actually know what a factory-fresh Pac-Man stick feels like (perhaps not even you.)  Usually, by the time anyone used them on a machine, the grommets were well broken in, if not quite damaged.  Personally, I like the feel of a good grommet stick over the spring centering, but they are not without their own idiosyncrasies.  Most don't know this, but those "centering grommets" were not designed by the arcade manufacturers to do the job they ultimately ended up doing.  They were an existing item, used in a very different industry, and re-purposed for the task.  As such, they suffered a lot of wear, and basically started being damaged almost immediately, being that they were subjected to forces well beyond what their design anticipated.  That's why when you buy a used grommet stick, the grommet is usually destroyed.  They are quite stiff when new.
After someone beats the heck out of them in a commercial environment, and the restriction becomes worn, then it's possible for the actuator to reach farther than when new.  I haven't seen this ability to push the actuation far enough to bend switch levers on a new stick, but it's possible if the levers have been bent inward.  If anything, diagonals on a Super might be too sensitive for some, especially after using a Competition.  Regardless, your assertion that the Reunion "is a Super" is just incorrect.  Completely different shaft, actuator and restriction pattern.
Again, not entirely correct.  Rubber grommets absolutely do not have a "uniform resistance".  Resistance with a rubber grommet starts out small, and increases very rapidly the farther off center it is pushed.  4-way joysticks typically have a fairly long throw, so that higher resistance will be reached pretty quickly in use.  It's also important to note that the farther off center the grommetted shaft is pushed, the more twisting of the grommet center occurs, thereby increasing the damaging effects of using them in this manner.  This is why they are torn up so badly on older machines in disrepair.  On the other hand, the spring centering is much more uniform in resistance, with the exception of the small bump at the center.  My own tests show that a Super, extended to the restriction limit, requires about .75lbs of force.  A grommet centered stick, with the same shaft length, takes about .97lbs of force to move the actuation the same distance.  So yes, it's true that grommet sticks are smoother across center, but that comes at a price of longevity and more resistance.  It's also worth noting that a Competition, like other spring centered sticks, has the same positive centering, so it's nice to see that it doesn't bother you on that model.
Bear in mind that in this particular assembly (one I know you have not tried before "poo-pooing" it) there is further reduction of forces required for actuation, due to the fact that the 100gram activation force switches have been replaced with real leaf switches, which not only reduce activation forces by ~90grams, but also have a near zero distance "reset" before being activated again.
In other words, a little experience and data from the actual item can go a long way when making an assessment.
« Last Edit: December 29, 2013, 11:06:32 pm by RandyT »
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
« Reply #45 on: January 03, 2014, 07:49:17 pm »
Just put one of these along with a leaf switch button in a Reunion cab I purchased for a friend.  I only played a couple of games to test it out but it worked great and felt far better than the original stick.  The only complaint I have is it will occasionally make a "pop" sound as you play.  I'm not sure what part is popping against what other part, but something is happening there.  Seems like a minor issue though, as long as it doesn't get worse.
Donkey_Kong
    • CNC Machines
« Reply #46 on: January 03, 2014, 10:51:51 pm »
Whats the difference between this stick, an original pac man stick, and an original ms pacman stick?
Heck while we're at it, what about that Donkey Kong stick? Is this (the pac-pro) a good DK stick as well?
Jumpman64
« Reply #47 on: January 03, 2014, 11:09:23 pm »
Well original Pac & Ms. Pac sticks I think had a wooden ball, and they were centered by a rubber grommet.  Otherwise, fairly similar.  DK sticks are quite different and I would not recommend this stick for use in a DK.  Real DK sticks are not that hard to find and replacement springs, restrictors, and other parts can be found at Mike's Arcade so I would suggest to go that route.
« Reply #48 on: January 04, 2014, 12:04:34 am »
any chance of these getting made with a slightly longer shaft for wood panels?
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #49 on: January 04, 2014, 01:16:16 pm »
The Pivot Cylinder is upside down. When the stick was removed to mount it, it got put back on upside down.  The wide end of the pivot needs to be at the bottom, not the top of the base.  I had the same popping sound in my reunion stick & it was caused by the pivot cylinder being upside down.  Once it is in right, there will be NO popping sound at all.
« Last Edit: January 04, 2014, 01:19:29 pm by tron84 »
Jumpman64
« Reply #50 on: January 06, 2014, 01:14:18 pm »
Hrmm, well, rhis is how it was:
« Reply #51 on: January 06, 2014, 01:23:13 pm »
That looks correct.  Most likely this sound is caused by the internal part at the bottom of the spring, which is designed to shift.  It should smooth out as the parts start to wear a bit with use, but if you like, you can probably use some white lithium grease where the plastic parts meet to allow that part to slide more smoothly.  If you use the spray version, you can probably do it without the need to open the base.
But I would use it a while to break it in first, as it probably won't be necessary after that.
Jumpman64
« Reply #52 on: January 06, 2014, 01:42:39 pm »
I think I figured it out -- the dust washer was below the panel :)  plays perfectly now!
2600
« Reply #53 on: February 06, 2014, 09:32:09 am »
Randy, when using the Pac-Pro with the Versaball2 shaft have an option to keep it at it's original height?
« Reply #54 on: February 06, 2014, 09:35:21 am »
  • Last login:February 03, 2026, 06:27:46 pm
« Reply #55 on: February 06, 2014, 09:36:31 am »
I just wanted to follow up and say that I'm still lovin' mine!!!!
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #56 on: February 06, 2014, 10:40:34 am »
I wonder.
Since the Versaball2 shafts fit Super bases, shouldn't they fit this stick (same base, I think?) for folks wanting Wood panels?
Similarly, these sticks would fit the 8-Way Super/Super-Pro bases for "Standard" height play, rather than the 4" Robotron-Style stick length that you get with a metal panel on the Versaball2 shafts...
Anybody have the parts to mix/match and try this? No real need, just a sort of academic wondering. :)
dfmaverick
« Reply #57 on: February 06, 2014, 12:54:05 pm »
Pac-Pro:  Standard 10mm shaft (compatible with VersaBall2 shafts), longer throw, bolt-up compatible with standard HAPP, X-arcade, etc.. type mounting patterns, deeper footprint, able to take serious abuse.
« Reply #58 on: February 06, 2014, 01:09:11 pm »
The VersaBall2 shafts are a stepped design, with a thicker upper shaft, so the minimum length is fixed.  It can be longer, and extra grooves are there for that, but not shorter.  I have some hollow stainless shafts, but extra e-clip grooves would need to be added to do this.  I'll look into some shorter shafts for these.
Define "slightly" :).  They would need to be an extra 3/4"+1/8" long to cover most of the bases.  I'm not sure how this would affect the feel and operation of the stick.  The leaf switches could be adjusted to compensate for the extra swing caused by the added length, but the restriction size is fixed.  By time the switch reaction speed was brought back, there would be possibly unacceptable crossover (diagonals) with a longer shaft.  An extra restrictor plate would probably be required to do this properly.
Yes, they would.  I'm in the process of getting some replacement shaft parts made for other sticks, and we are almost out of the VersaBall2 shafts.  The VB2 shafts are great for folks with metal panels, looking for a "Robotron" length balltop.  A couple of these with the Super-Pros, and it'd be pretty close to the performance of the original in that regard.  But I think the next revision will be a bit shorter, so maybe we can kill a couple of birds with one stone.  It would be great to have a single shaft that does it all, but the visible grooves on the upper part of the shaft would be unattractive when used at the longer settings.  I may have a solution...
2600
« Reply #59 on: February 06, 2014, 01:23:42 pm »
Just to make sure I'm understanding this correctly since there was a flood of questions.  The current VersaBall2 would make the ball up a bit higher then the stock shaft?  Do you know how much higher?
« Reply #60 on: February 06, 2014, 01:33:46 pm »
slightly as in, the CP is 1/2" MDF.
mann0mann
  • Last login:June 25, 2016, 12:31:54 pm
  • Still looking for the right project...
    • My Hobby Store
« Reply #61 on: September 03, 2014, 07:40:31 pm »
I apologize for asking what appears to be the same question, but it's just not clear to me after reading this several times.
If you wanted to buy a Pac-Pro and use the Versa-ball 2 shaft on it so you could change the balltop.  Does the Versa-ball 2 shaft allow for the exact same height as the stock shaft?
I understand it *CAN* be longer...but can it be the same as the stock height?
I want to install one in a metal midway CP control panel, but I would like the ability to have a custom balltop instead
« Last Edit: September 04, 2014, 03:10:06 am by mann0mann »
copyimitation
  • Last login:November 06, 2019, 12:03:56 pm
  • Looking for Ring of Destrucion II
« Reply #62 on: August 08, 2017, 10:56:52 am »
I know this post is old, but I don't see any others regarding these two joysticks. (Leaf Pro vs Pac-pro Leaf) I've got a 9-in-1 cab with DK, Ms. Pacman, Dig Dug, Frogger, Burger Time (that's what i play of the 9) and I'm looking for a 4 way leaf switch. My cab is an old Kozmic Krooz'r that someone converted to a boxing game years ago. So the CP is metal and has an old pair of 8 way leaf sticks now. Which of the two sticks would you recommend?
swahiliboy
  • Last login:January 03, 2026, 05:58:34 pm
« Reply #63 on: August 09, 2017, 09:36:01 am »
copyimitation,
I'm just getting going on my set up, but I have two 8-way leaf-pros and a dedicated 4-way pac-pro.  The pac-pro feels great for 4-way games, and it was miles better than my 8-way configured leaf-pros.  Not sure how it would compare to the leaf-pro configured to be a 4-way.  My only issue with the pac-pro was installing it in my 3/4" control panel, but I got it to work.  Presumably you wouldn't have that issue with your metal control panel.  Hope that helps a little bit.
