Author Topic: GroovyMAME 0.171 - SwitchRes v0.015m  (Read 310802 times)
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: GroovyMAME/GroovyUME 0.153 - SwitchRes v0.015b
« Reply #160 on: April 28, 2014, 06:11:47 am »
Yep, Same result as me.
Calamity, i just had another look, and the video modes chosen between the 2 versions change..
Maybe that's got something to do with asteroids looking so bad?
sean_sk
  • Last login:August 06, 2019, 10:27:48 am
  • If quizzes are quizzical, then what are tests?
« Reply #161 on: April 28, 2014, 06:17:25 am »
Did you get my PM in regards to an issue I'm having with triple buffering causing missing polygons and textures in Ridge Racer and Rave Racer and all vector games being very dark?
Hi sean_skroht, yes I saw your message. Although I'm not seeing it here, I'd say it's caused by the multithreading associated to triple buffering causing graphic glitches. You may try enabling -video d3d for these particular games, keeping triple buffering on (multithreading) so it will bypass the half frequency issue when using d3d. If this doesn't help, I guess there's nothing we can do about it.
Thank you for your suggestions. I was able to fix the issue by forcing -video d3d in Hyperspin paramaters for all games. Thanks for that mate.
« Last Edit: April 28, 2014, 06:48:28 am by sean_skroht »
  • Last login:Today at 06:51:12 am
« Reply #162 on: April 28, 2014, 07:08:34 am »
I'm afraid that's an error my friend. Forcing -video d3d in the command line just overrides the fix that's been implemented right for you. You'll get 50% speed in any other game that is running with an interlaced mode and without triple buffering enabled.
The -video setting in mame.ini is not being ignored. It's just that now when the specific conditions are met (W7 & interlaced mode) direct draw is selected regardless the default setting that's specified in mame.ini. As with any of the automatic options set by SwitchRes, this is only a step of priority above mame.ini, but below any other .ini file or command line. So you can always force any setting by creating a game.ini, or driver.ini, or even horizont.ini or whatever.
« Reply #163 on: April 28, 2014, 07:13:44 am »
Hi Sledge,
A different mode is picked because starting with v0.153 Asteroids is reported as having refresh of 61.xx. If you want GM to pick the old mode just let in know that the resulting frequency is acceptable:
crt_range0 15450.00-16250.00,50.00-65.00,3.910,4.700,6.850,0.190,0.191,1.018,0,0,192,288,448,576
Vector games look different probably because now DirectDraw is used insted D3D. Use the specific vector options to increase the beam width, brightness etc.
« Reply #164 on: April 28, 2014, 07:20:31 am »
Things improved a lot, BTW there are some strange behaviours that I can't explain:
Hi Haggar,
A couple of notes:
- Comparing 0.149 vs 0.153 is cheating because with 0.149 you have modeline generation enabled, so obviously the target refresh is achieved. If you enable modeline generation for 0.153 you'll get the exact same refresh... just forgot to mention this the other day :)
- It's very strange that GM runs snowbros at 104% when the it's actually picking a 57 Hz modeline. I'd suggest to repeat the test right after a fresh reboot without running any other version of GM before. I'll try to reproduce the problem here anyway.
Haggar
  • Last login:February 13, 2017, 05:12:32 am
« Reply #165 on: April 28, 2014, 08:03:56 am »
Hi Haggar,
A couple of notes:
Ah, ok sry for that.
Ok, I'll try.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #166 on: April 28, 2014, 08:37:22 am »
Is there a list somewhere of all the possible .ini files? I've been wondering for a while what the horizontal one was.
« Reply #167 on: April 28, 2014, 10:59:56 am »
You can check the code in emu_options::parse_standard_inis here: http://git.redump.net/mame/tree/src/emu/emuopts.c
adder
« Reply #168 on: April 28, 2014, 11:05:03 am »
Quote from: Calamity
...starting with v0.153 Asteroids is reported as having refresh of 61.xx
cool im glad thats been officially changed now as asteroids doesnt run smooth otherwise
http://www.mameworld.info/ubbthreads/showflat.php?Number=2819540
Haggar
« Reply #169 on: April 28, 2014, 05:08:34 pm »
Hi Haggar,
A couple of notes:
Ok, I'll try.
Tried, but the problem remains.
I've also tried turning on modeline generation:
E:\EMULATORI\MAME>groovymame32_0153.015b.exe butasan
SwitchRes: [butasan] (1) horizontal (256x240@54.00)->(256x240@54.00)
Average speed: 110.92% (9 seconds)
E:\EMULATORI\MAME>groovymame32_0153.015a.exe butasan
Average speed: 100.01% (6 seconds)
Log attached
cools
    • Arcade Otaku
« Reply #170 on: April 28, 2014, 05:13:22 pm »
Oh, its actually mame source? Thanks, useful info :)
As an on topic aside, I've seen similar weirdness as Haggar has with games not seeming to throttle properly with 153 15a and 15b. I've not had any time to do some diagnostics on it though so can't offer anything more than a me too.
ozfalcon
  • Last login:November 30, 2025, 12:40:52 am
  • ZSystem
« Reply #171 on: April 28, 2014, 06:44:58 pm »
Ok, I'll try.
When I run snowbros @ 60hz I get Average speed: 104.38%
So It sounds like it may be picking it, But not switching to it?
<Modified: Removed redundant info>
« Last Edit: May 02, 2014, 02:40:44 am by ozfalcon »
Haggar
« Reply #172 on: April 29, 2014, 02:30:13 am »
Ok, I'll try.
I've tried changing refresh rates through mame sliders controls. Forcing games with this issue at 60Hz they all run at 100%.
« Last Edit: April 29, 2014, 02:31:52 am by Haggar »
« Reply #173 on: April 29, 2014, 03:09:38 am »
I spotted the problem last night, indeed it's caused by a change I introduced in the DirectDraw part. I'll have a fix today.
Haggar
« Reply #174 on: April 29, 2014, 04:31:41 am »
Great!  :notworthy:
One quick question before updating my romset: I've read in the past that the triple buffer option is managed automatically by GM.
I know that this option introduces massive lags to controls, is there a way to force it off and be sure that it will not be activated?
Sledge
« Reply #175 on: April 29, 2014, 05:33:00 am »
Hi Sledge,
there's no brightness setting for Vector games?
under CORE options i've got:
antialias
beam
flicker
putting brightness 1.2 or 1.1 (under Core vector options) does make the screen brighter (and blurred)... but we just need the vector lines to be brighter rather than the whole screen?
« Last Edit: April 29, 2014, 05:53:59 am by Sledge »
« Reply #176 on: April 29, 2014, 05:46:52 am »
putting brightness 1.2 or 1.1 (under Core vector options) does make the screen brighter... but we just need the vector lines to be brighter rather than the whole screen?
Use the beam option.
http://forum.arcadecontrols.com/index.php/topic,118159.msg1254032.html#msg1254032
Sledge
« Reply #177 on: April 29, 2014, 05:58:35 am »
yeah that does help a fair bit :)
Thanks !
« Reply #178 on: April 29, 2014, 06:00:47 am »
You can control exactly when -triplebuffer is going to be used by means of the -syncrefresh_tolerance option. This option is set to 2.0 Hz by default. It means that when the difference between the native game's refresh and the modeline is higher than 2.0, -triplebuffer will be used instead of -syncrefresh, in order to keep the game speed deviation in a reasonable range. Of course you can increse the -syncrefresh_tolerance value as much as you like, e.g. if you set it to 10.0 Hz it probably won't use -triplebuffer in any situation. Of course there is a catch: games like galaga will run very slow on a horizontal arcade monitor.
That said, don't be too scared about triple buffering: the main source of input lag associated to triple buffering in the popular culture just does not happen with GroovyMAME. This is because we set things so that the frame queue arranged by DirectX is bypassed.
The obvious problem with triple buffering is the unavoidable loss of 1:1 frame mapping that leads to choppy scrolling. That's why it's just a last resource setting rather than a desirable feature.
Finally, for -triplebuffer to work in the intended way you need to have -multithreading enabled too.
Haggar
« Reply #179 on: April 29, 2014, 06:10:34 am »
Thanks.
Can you provide a list of reccomended settings to get less lag as possible (mantaining v-sync on of course)?
« Reply #180 on: April 29, 2014, 06:24:25 am »
Thanks.
Check this: http://forum.arcadecontrols.com/index.php/topic,133194.msg1377633.html#msg1377633
In the attached picture, you'll see the settings I was using.
« Reply #181 on: April 29, 2014, 08:08:19 am »
Haggar
« Reply #182 on: April 29, 2014, 08:20:18 am »
Thanks!!
Thanks.
So it's better using d3d instead of ddraw.
« Reply #183 on: April 29, 2014, 04:06:47 pm »
With -frame_delay enabled (any value above 0), d3d = ddraw
Without -frame_delay, d3d lags 2 frames more than ddraw.
Haggar
« Reply #184 on: April 29, 2014, 06:04:31 pm »
Thanks Calamity.
I've tried your new release, problems gone!!  :applaud:
cools
    • Arcade Otaku
« Reply #185 on: May 07, 2014, 05:51:04 am »
Is it normal that the font rendering when "orientation vertical" is set does the attached?
I've tried with multiple games and fonts, including the fallback font as pictured - all the same unusable scale.
Sledge
« Reply #186 on: May 07, 2014, 06:46:40 am »
How do the Cave games run for people in GM 153?
IE: Muchi Muchi Pork for me runs like a dogs breakfast... speed is all over the place even going down to about 54% at times..
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #187 on: May 07, 2014, 06:53:00 am »
For what I heard, cave sh3 games are very cpu-hungry, so it could be related to your hardware configuration.
Earth could be the hell of another world
« Reply #188 on: May 07, 2014, 07:15:45 am »
Well that's not normal, or at least desirable. Please post a log, so I can use it to clone your system here and see why that happens.
I have a pending task regarding some aspect ratio & fonts issues, specially affecting SDL and -cleanstretch 2, which hopefully will get fixed soon, and probably looking inside this will help with with related problems like this one and the other one you posted.
Sledge
« Reply #189 on: May 07, 2014, 08:59:15 am »
Yeah i just OC'd from 3.16Ghz to 3.8Ghz, and it went from a minimum of 52% to a minimum of 72% (demo play)
strange thing though.... if i press F10 to unthrottle mmpork.... it doesn't drop below 100%.. not even close, maybe 120% minimum
I can't actually get a credit in as it gives a COIN ERROR lol..
« Last Edit: May 07, 2014, 09:20:18 am by Sledge »
cools
    • Arcade Otaku
« Reply #191 on: May 07, 2014, 09:48:43 am »
I've tried on different systems as well.
I'll grab a log of one of them shortly, along with the ini.
cools
    • Arcade Otaku
« Reply #192 on: May 07, 2014, 10:01:18 am »
Attached. Also tried "orientation rotate" and same issue.
Doesn't happen on galaga88, if that helps.
MAME.INI renamed to allow for upload.
« Last Edit: May 07, 2014, 10:03:35 am by cools »
cools
    • Arcade Otaku
« Reply #193 on: May 07, 2014, 10:12:07 am »
(cleanstretch 2 also breaks vector games really well  :lol )
« Reply #194 on: May 07, 2014, 10:28:34 am »
Yes, I've seen very weird things with vector games lately. Have you tried it with -video ddraw?
BTW, the log correspoding with your picture would be the one I need.
cools
    • Arcade Otaku
« Reply #195 on: May 07, 2014, 10:38:35 am »
Right, hangon - I'll take a picture, the ini, and the log of it.
« Reply #196 on: May 07, 2014, 10:42:49 am »
I mean the one of the picture above http://forum.arcadecontrols.com/index.php/topic,135823.msg1437969.html#msg1437969
cools
    • Arcade Otaku
« Reply #197 on: May 07, 2014, 10:45:04 am »
I can't get you the log of that, it's in the past. I can reproduce the issue as much as you like though though with new picture(s) and associated logs.
All attached.
« Last Edit: May 07, 2014, 10:49:20 am by cools »
cools
    • Arcade Otaku
« Reply #198 on: May 07, 2014, 10:52:29 am »
Even more broken, just gives masses of "DirectDraw: Error 88760096 blitting to the screen" errors in the log.
cools
    • Arcade Otaku
« Reply #199 on: May 07, 2014, 11:05:44 am »
Cool. Definitely some weird behaviour. Don't really want to pepper you with logs, but another one I just spotted. If I change the ini I posted to "orientation horizontal" then galaga88 and invaders appear rotated vertically on the screen but fractionally stretched (filtered). ket is integer stretched. If I subsequently pass "-norotate" to galaga88, it appears in its natural orientation but it's running at 200%.
