Author Topic: need help fixing my megatouch jade  (Read 1463 times)
kellywba
  • Last login:November 23, 2013, 02:15:06 pm
« on: November 23, 2013, 01:23:47 pm »
i was wondering if any one could help, i have a mega touch maxi jade, was working fine , now when switched on it keeps saying auto test and nothing else happening can anyone help please or pass me in the right direction
kellywba
Re: need help fixing my megatouch jade
« Reply #1 on: November 23, 2013, 01:42:46 pm »
WHT CAN AUTO TEST MEAN , AS I DONT HAVE A CLUE AT ALL
grantspain
« Reply #2 on: November 23, 2013, 08:50:13 pm »
sounds to me that the screen has come on but not the pc itself-check first for fans running on the motherboard,if the fan runs then reseat or change the ram,if the fan does not run then check/change power supply and/or try to force motherboard to start by shorting the front panel header pins for power switch
if the game start after forcing the mobo to start up then you may have a dead cmos battery
ed12
« Reply #3 on: November 23, 2013, 09:24:41 pm »
to get get any kind of message on screen means it has passed monitor test,
ram test,rom test,cmos chk,
open the hood and a make sure yes your fans are working >all of them<
next find the i/o board..u willknow it because that is where the game key is
looks like what it sounds like.
on that board u will find a bank of switchs >8< in total
leave game powered on
turn switch 4 and 8 on  >8 could be 7< on yours.?
game should after a few secs say to u reloading factory defaults
do exactley as it says from there.
if all is good it should restore
wa la u got a game
if not report back
ed
