Author Topic: Side Panel Template  (Read 2366 times)
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
Side Panel Template
« on: November 22, 2013, 11:46:59 am »
I would like my template to be durable yet easy to work with.
Should I use regular ply or MDF?
When creating the template, which tool do you recommend? (Circular Saw, Jog Saw, Router, etc.)
Thanks for the guidance.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
Re: Side Panel Template
« Reply #1 on: November 22, 2013, 02:56:24 pm »
Im curious about this also as I have 2 templates that I would like to use as well, from what I have been reading people recommend MDF or ply.
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #2 on: November 24, 2013, 02:24:56 am »
MDF would be the better choice for a template. Especially if you seal the MDF against moisture. As for making the template, rough cut the outline first (circular saw or jigsaw as needed) then tighten up the edge with a router.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Side Panel Template
« Reply #3 on: November 24, 2013, 06:43:43 pm »
Mdf is the easiest to route, so from a control panel it's the one of choice but for a template of sides, sanded ply would work well too.  Remember to seal any wood you choose.
