Author Topic: Solved: maximus arcade vs dolphin 3.5  (Read 7561 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: November 09, 2013, 06:53:07 pm »
So my pc finaly is runing dolphin .iso just excelent  now the problem is when I exit the game (iso) from M.A. only close the play screen and the emulator screen stays on. Then M.A exit fine to emulator menu . when i try to play dolphin again only goes to black screen. Any help and sorry for my Spanglish . Thanks
« Last Edit: January 08, 2014, 04:08:02 pm by DeLuSioNal29 »
ark_ader
  • I glow in the dark.
Re: maximus arcade vs dolphin 3.5
« Reply #1 on: November 09, 2013, 11:26:00 pm »
Have you tried going to their website and asking the question?  ::)
Caparo8bit
  • Hyperspin/Maximus
« Reply #2 on: November 10, 2013, 02:19:47 am »
mmmmm nope and ya dont have to answer or check my post forums r made for some reason..
Bender
« Reply #3 on: November 11, 2013, 08:47:37 pm »
also best to ask under the Maximus sub forum
there might be some info there already
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« Reply #4 on: November 11, 2013, 09:50:47 pm »
Maximus forum has been too quiet. Nobody uses it?  :dunno
thomas_surles
« Reply #5 on: January 01, 2014, 03:59:19 pm »
I had the same problem but I just solved it for me. In preferences under configuration go to the "exit tab"
Check "use exit hooks" click on the blank space and type the key that you use for exiting games. I also checked the two boxes beneath it.
Caparo8bit
  • Hyperspin/Maximus
« Reply #6 on: January 04, 2014, 12:38:37 am »
THANK YOU SO MUCH
thomas_surles
Re: Solved: maximus arcade vs dolphin 3.5
« Reply #7 on: January 09, 2014, 05:31:41 pm »
No problem. Glad I could help for once.
Richardgregory
« Reply #8 on: January 09, 2014, 07:23:39 pm »
What profile do you use to setup Dolphin?  Some say to use Dosbox but I can't get it to work.
Also don't Wii titles need the motion controls to play the games?
thomas_surles
« Reply #9 on: January 10, 2014, 08:45:20 pm »
I use dosbox. At the bottom go to the "scan" tab and delete the media extensions and type. ".iso" without the quotes. Under the launch tab type "/e %file" also without the quotes. That is what I have and everything works fine.
I am just using GameCube on mine and have not tried wii. But it looks like you connect wii motes via Bluetooth.
