Author Topic: Found out why MAME'S HLSL always looked like ---steaming pile of meadow muffin---  (Read 31117 times)
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
Go into prescale.fx and find this:
sampler DiffuseSampler = sampler_state
   Texture   = <Diffuse>;
   MipFilter = LINEAR;
   MinFilter = LINEAR;
   MagFilter = LINEAR;
That's why MAME's HLSL filter always looked like blurry dogshit. It was doing linear filtering on everything before you even got to adjusting the settings.
Just change it to this to get rid of the ---smurfy--- N64 filtering, and magically, HLSL will look sharp like a REAL arcade monitor, and you can actually use the defocus settings now to find the sweet spot between PC and arcade sharpness.
   MipFilter = NONE;
   MinFilter = NONE;
   MagFilter = NONE;
If you want to see before and after shots using the same settings, here you go.
Before:
After:
See? NOT blurry crap anymore. Actually sharp. Like a real arcade monitor. Yeah. Yeaaah! Like an ACTUAL arcade monitor is crisp and sharp.
http://memegenerator.net/instance/42680609
« Last Edit: November 03, 2013, 07:49:21 pm by bulbousbeard »
machyavel
  • Last login:December 25, 2016, 10:23:52 am
Very nice and much useful tweak!
bulbousbeard
More glorious screenshots:
B2K24
  • Last login:June 10, 2025, 10:17:56 am
@bulbousbeard: can you pastebin or put your HLSL settings from mame.ini here for a test please?
mcilrain
  • Last login:February 09, 2014, 06:45:41 pm
Thank you!
I was trying to get hlsl shaders to make a high-resolution CRT (PC) monitor look like a PVM but gave up due to being unable to get rid of the blur.
I hope that this becomes the default.
bulbousbeard
The settings I'm using now:
http://pastebin.com/zQZysq4y
Note that I'm not using the standard aperture.png.
B2K24
Thanks for posting those. Why have you set your prescale so high at 8?
I was told 3 or 4 is good enough even at 1920X1080 display.
bulbousbeard
I run at 2560x1600 on one of my computers.
  • Last login:Yesterday at 04:18:09 am
Hi bulbousbeard,
I'd say the average arcade monitor is somewhere between your "before" and "after" pictures. I find your results after the patch a bit too sharp, even if arcade monitors are not simply blurry as some pleople think: they do blend colors along the scanline to some extent.
This is my current HLSL setup (GM 0.149), notice the shades on Zandief legs, for instance:
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               1
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           1024
hlsl_snap_height          768
shadow_mask_alpha         0.15
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.0
pincushion                0.02
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.7
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.2,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.2,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 0.85,0.15,0.0
grn_ratio                 -0.1,1.1,0.0
blu_ratio                 -0.075,0.0,1.075
saturation                1.0
offset                    -0.15,-0.18,-0.18
scale                     1.15,1.18,1.18
power                     1.1,0.9,0.7
floor                     0.01,0.0,0.01
phosphor_life             0.0,0.0,0.0
PS: Note this runs at 30% on my system, so it's no where near being playable, it's just to show that normal hlsl is not necessarily blurry.
EDIT: Colors here are much brighter than on the picture, it seems the site converted it from .png to .jpg and the colors are screwed.
« Last Edit: November 04, 2013, 08:25:58 am by Calamity »
B2K24
Thank You Calamity for sharing your settings  ;D
To be fair I grabbed those settings somewhere ;)
bulbousbeard
What's missing in Calamity's screenshot, though, is the crispness of a real arcade monitor. It's impossible to get it with the linear filter.
The thing about this change is that it means you can actually use the defocus option now (you couldn't before because it would be way too blurry).
I agree about the sharpness. I had defocus on 0, and with no linearing filtering, it is a bit too sharp. If you set defocus at like 1.0 or 1.5, it's right in between. It still has the crispness of a CRT, but there's some bleed.
« Last Edit: November 04, 2013, 03:15:55 pm by bulbousbeard »
bulbousbeard
Here's what I'm talking about. Here are Calamity's HLSL settings with the modification and a defocus setting of 1.5.
See how you're still getting the subtle blur effect yet maintaining the crispness of the image?
The image will simply never be crisp with linear filtering applied to it first.
jdubs
  • Last login:January 03, 2018, 09:06:27 am
REALLY good tips on accurate HLSL setup.
http://shmups.system11.org/viewtopic.php?f=6&t=45026
-Jim
SMMM
  • Last login:October 10, 2020, 09:19:13 pm
Is HLSL applicable when used on a real 15khz arcade monitor, or is it something that's only applied on a modern monitor?
cmoses
Very interesting I will have to give these a try.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
This is by far the closest to an high-end arcade CRT in this thread. The ones in the beginning are too sharp, and the original Calamity ones are too soft - not sure what on earth was going on with your own "LINEAR" settings as those were atrocious.
adder
hlsl was designed in mind to attempt to make the more modern types of monitors (eg. lcd) look more like a real (crt) arcade monitor
bulbousbeard
Hi Cools,
It's because the screenshot with the default prescale.fx had defocus 1.5 set. You basically can't use defocus at all with linear filtering, because you're getting double blurring.
By removing the linear filter, you can actually use the defocus setting to decide how blurry or sharp you want the image to be.
isamu
  • Last login:February 01, 2026, 06:15:45 am
How do you achieve these results using SweetFX instead of HLSL?
cmoses
Bulbousbeard,
Did the first post get edited? It looks to be missing some information.
Also what aperture.png are you using?
Sent from my iPad Mini using Tapatalk HD
mcilrain
What is it with emulator developers and blindness? None of them seem to know how a CRT is supposed to look.
mmg1design
  • Last login:July 30, 2016, 03:22:09 pm
    • My Website
Thanks! these changes make a huge difference.
Instruction Cards for Street fighter games and other fighting genre. Download Here
Boulotaur2024
  • Last login:January 26, 2014, 03:50:42 am
This looks absolutely fantastic mate.
Can you confirm the HLSL settings you posted here reflect these screenshots ?
isamu
Boulataur since you're here, I have a couple of questions re SweetFX....has there been any changes/improvements to the CRT shader in the latest version of SWFX? Are we able to achieve scanline effects similar to MAME's HLSL effects, and what's been posted here in this thread? Has any further tweaks/settings ability been added? Will the new eFX injector bring anything new to the table related to the CRT shader?
Just curious
8BitMonk
Thanks for this info, after doing some testing I'm still amazed at how good the HLSL settings looks on my LCD display. I have an AVGA and multi-sync arcade monitor in my cab for comparison and while this isn't as good, it's come a long way and is getting remarkably close. I never thought you'd be able to fully reproduce the arcade look on newer monitors but this is starting make me wonder. I'll bet if you put it behind a tinted glass it'd be even closer.
bulbousbeard
I spoke with MAMEdev today, and this change is going to be incorporated in the next version of MAME.
http://mame.dorando.at/svn/?rev=26400
Sounds great, bulbousbeard. I still need to test this myself here.
