Author Topic: Rowe CD-100E not working  (Read 6735 times)
Z0MBIE
  • Last login:March 04, 2014, 06:13:03 pm
  • Dead and loving it!
« on: October 31, 2013, 10:47:25 pm »
I just bought 4 Rowe CD-100E jukeboxes and all look complete but do not work and I really don't know where to start. The 2 I plugged in seem to turn on and I hear the amp make noise, I do not see any errors on LED's or on the front but I can not get anything to play or the carousel to even do anything. I put it in Service mode and pressed cancel on the carousel and I was told this should make it spin but I get nothing. Any help would be greatly appreciated.
ed12
Re: Rowe CD-100E not working
« Reply #1 on: October 31, 2013, 10:58:03 pm »
your orange wire should be at 28 volts
if not chk the fuse for it
did u get a manual with atleast 1 of them ?
ed
Z0MBIE
« Reply #2 on: October 31, 2013, 11:13:53 pm »
Unfortunately did not get any manuals. Where is this orange wire located or should I say where should I check the voltage at?
ed12
« Reply #3 on: October 31, 2013, 11:22:05 pm »
i olny have nsm manuals for the cd-100,my laster star may be the same ?
but i best lay back until ami-man/ken-layton or shawn chime in
then i will be able to nail the model and help u
ed
Z0MBIE
« Reply #4 on: October 31, 2013, 11:36:38 pm »
I appreciate your help.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #5 on: November 01, 2013, 07:00:43 am »
You need to check that the power supply LEDs are all on and voltages are correct.
Your first job however is to buy the correct manal so you at least have a fighting chance of moving forward.
Regards
Alan
Alan Hood
ami-man
UK
Z0MBIE
« Reply #6 on: November 01, 2013, 11:28:16 am »
Working on getting a manual.  The Central Control Computer has the 5V LED lit and on the carousel also has the 5V LED lit along with the Index LED.
ed12
« Reply #7 on: November 01, 2013, 02:09:33 pm »
all leds
the power supply will have 4 or 5
the ccc should olny have 1
ed
Z0MBIE
« Reply #8 on: November 01, 2013, 02:26:29 pm »
The power supply does not have any LEDs.
ed12
« Reply #9 on: November 01, 2013, 02:57:46 pm »
cd-100-c
colse enough for the ppl we go out with
cr516=led=8 vdc
cr514=led=28 vdc
cr515=led=28 vac
so there u have it 3 leds
they have to be there
power-supply my nick power-supply
if u cannot see them  ?
open the hood and look for them
ed
Z0MBIE
« Reply #10 on: November 01, 2013, 03:11:44 pm »
Ok, my bad. I turned the lights out then seen the 3 LED's way down on the side and all are lit.
ed12
« Reply #11 on: November 01, 2013, 03:27:22 pm »
ok it is the same..thought it was
let me chk the ccc for ya
them 3 leds on tell alot for the trick of the tail here
the thump u here means the amp is up but not muted
a side note here if these were re-retor's  ie had a mode done for mp3
and not reverted back..this will be the exact problem.
i will look in my crib notes
ed
Z0MBIE
« Reply #12 on: November 01, 2013, 03:35:04 pm »
I was also told while in service mode press 80 then popular and that will give error codes but it comes up No errors.
ed12
« Reply #13 on: November 01, 2013, 03:46:57 pm »
u need to give me a shot to go through the ccc
there is a way to get the error codes up
but i need to see my crib notes first
ami-man maybe be able to handle this 1 ?
as the nick is fulnet in rowe
i will be asking pointed questions
wish u had a maual..victory glass has them
http://www.victoryglass.com/
u may need to call them if it is not listed
ed
Z0MBIE
« Reply #14 on: November 04, 2013, 06:22:01 pm »
Does anyone have a PDF of the manual?
  • Last login:October 05, 2025, 04:52:10 pm
« Reply #15 on: November 06, 2013, 10:19:06 am »
not that i know of anymore. there used to be a website you could get them from, but they went pay.
you can buy them off ebay for a few bucks though.
