March 20, 2026, 03:31:39 pm
From what I've seen in other's projects, they're pretty much screwed or nailed in.(though I'm sure it wouldn't hurt to glue as well).I suppose you could dado them in as well.
They use dado for more surface area and glue. The glue is the powerhouse here. If you don't do dado you need to use screws or 15ga nails or lower and glue. That is if its a traditional arcade monitor. If its just an LCD tv you could get away with smaller nails and glue.
