Author Topic: Can not get drivers installed on HD 4350  (Read 5588 times)
trev1976
  • Last login:December 15, 2025, 02:16:08 am
    • Girls In Your City - Anonymous Sex Dating - No Verify
« on: October 27, 2013, 07:03:22 am »
Well i had a go at setting this up last night , messed around for about 3hrs and got no where really , im pretty sure the crt driver wont install
I followed the instructions that are posted on AO and it looks like the driver is installing correctly from the set up but when i run vmmaker it says no driver detected an if i run arcade osd it also says at the top , no crt driver found ? if i try to run the groovymame.exe it says i have a problem with switchres
its driving me mad now :cry: i tryed uninstalling the previous drivers a few times but it didnt work , maybe when i updated XP windows also updated my GPU and it is causing a conflict ? any ideas , oh how i love setting computers up
« Last Edit: October 27, 2013, 08:57:19 pm by trev1976 »
https://SecreLocal.com - Chat Local Singles - No Verify - Anonymous Sex Dating -   Dating Chat Local Live
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: Can not get drivers installed on HD 4350
« Reply #1 on: October 27, 2013, 08:06:00 pm »
Which HD4350 you got?
Search for HD4350 on here, you'll find a few people with issues, and their fixes.. there's even one just a few threads down...
trev1976
« Reply #2 on: October 27, 2013, 09:00:29 pm »
I bought it so long ago i cant remember now  :banghead: ,i think its a sapphire but ill have to take a look and let you know
it looks like this one
« Last Edit: October 27, 2013, 09:07:28 pm by trev1976 »
Sledge
« Reply #3 on: October 28, 2013, 12:28:45 am »
That could be anything man :)
Find out and let us know..
Did you look at the other threads to do with HD4350?
trev1976
« Reply #4 on: October 28, 2013, 03:45:26 am »
Yeah i had a look through those threads , very interesting
I think my best bet would be to boot into safe mode and delete all gpu drivers , ( whats the best software for this ? ) and then add the modified files to the driver and then reinstall in safe mode ? sound good ?
Sledge
« Reply #5 on: October 28, 2013, 04:02:13 am »
well you need to find out if your card is the same..
get the device ID info like they have.. if it matches, then use the files that match etc..
trev1976
« Reply #6 on: October 28, 2013, 02:20:59 pm »
ok , ill probably get round to this at the weekend , thanks ;)
trev1976
« Reply #7 on: October 29, 2013, 03:26:21 pm »
silly question but how do i find the device ID , thanks
  • Last login:Yesterday at 03:36:00 pm
« Reply #8 on: October 29, 2013, 05:33:02 pm »
This is for disk devices but it's the same for video cards:
trev1976
« Reply #9 on: November 03, 2013, 06:27:52 am »
Ok found my device id , its not the same as in the other threads
PCI\VEN_1002&DEV_954F&SUBSYS_174B174B&REV_00
PCI\VEN_1002&DEV_954F&CC_030000
trev1976
« Reply #10 on: November 05, 2013, 02:44:22 am »
Any ideas what i should do , i see in one thread this guy had the same card
http://forum.arcadecontrols.com/index.php/topic,123037.0.html
but he ended up installing XP32 , i really wanted to stick with 64
« Reply #11 on: November 05, 2013, 05:16:50 am »
It's most likely this.
I've double checked the drivers and they do contain your specific card device number so there's nothing wrong with them, and they indeed got installed.
It must be Windows replacing them by its own newer version.
What you have to do is to remove the existing version manually. You do that by entering the device manager -> video cards -> driver -> uninstall. When you reboot, you should see an exclamation and the card should not be recognized. Iterate the process until you get it. Then it's ready to install CRT Emudriver.
trev1976
« Reply #12 on: November 05, 2013, 02:25:05 pm »
ok thanks , ill try again this weekend , windows hates me   :banghead:
trev1976
« Reply #13 on: November 09, 2013, 03:07:36 pm »
still cant get this to install  :banghead: any good programs i can use to clean drivers in XP64 ?
« Reply #14 on: November 13, 2013, 12:29:23 pm »
Hi trev1976,
If you can't seem to get the driver installed, it could be the installation program has not properly finished updating the registry, but the driver is actually installed. Try setting this in vmmaker.ini (by the end):
AnyCatalyst = 1
This will force VMMaker to install the modes. Then select 640x480@60 and restart. You should have 15 kHz then.
