Author Topic: Any idea how to fix this FIX IT FELIX CRT issue I am having?  (Read 960 times)
kaneda
  • Last login:April 18, 2014, 03:42:04 pm
« on: October 24, 2013, 03:30:56 pm »
Hey guys,
When hooking up Felix to a CRT, the bottom inch of the play area is getting cut off.  Any ideas on how to fix this?  Using all of the right video cards, JPAC/JAMMA to VGA stuff necessary to make this work.  Is it a setting thing?
paigeoliver
  • Awesome face!
Re: Any idea how to fix this FIX IT FELIX CRT issue I am having?
« Reply #1 on: October 24, 2013, 03:55:39 pm »
That is something you should be adjusting on the monitor. If the monitor is running vertically oriented then horizontal position and horizontal width are what you want to adjust (you usually need a special plastic allen wrench to adjust horizontal width). If the monitor is running in standard orientation then it will be the vertical controls.
meyer980
  • Last login:August 16, 2025, 11:20:05 am
  • Building fun things for fun
    • sergiostuff.com/2020/04/15/felix-son-arcade-game/
    • Sergio Stuff
« Reply #2 on: October 24, 2013, 04:29:07 pm »
If you're running the leaked Disney official copy, it's a little fussy with the graphics card. I ran it on a couple different computers and anything with integrated graphics would give me a similar problem as you. (except in my case it was the left side of the monitor)
A combination of messing with monitor settings, and your graphic card settings, may be the answer. (it was for me)
Does it work fine if you hook up to an lcd?
