Author Topic: can I put a ls32 shaft in a jlf?  (Read 1128 times)
« on: October 24, 2013, 01:20:30 pm »
Basically as a stop gap until I get long jlf shafs from paradise. Have to use the actuator from the ls32 cause the shaft is significantly wider. What say you will it play nice with the sanwa micro switches and restrictor? Or am I doomed to wait at the mailbox?
Re: can I put a ls32 shaft in a jlf?
« Reply #1 on: October 24, 2013, 07:10:51 pm »
No you cannot as it turns out.  You can however lose the clip to your ls32, ruin its shaft trying to find a suitable replacement and drop your jlf.  :angry:
« Last Edit: October 24, 2013, 07:16:43 pm by harveybirdman »
  • Last login:Yesterday at 05:02:05 pm
