December 05, 2025, 07:01:03 pm
Cool. Would like to see the pics of the repaired area. As far as painting the laminate, there are some good primer paints out there that are made for laminate pre paint prep. Unfortunately I can't remember the brands. I'm sure Lowes or Home Depot can help. My only suggestions are to NOT skimp ($$) on the this step and to let the primer cure THOROUGHLY before proceeding. Zinnser products come to mind...
Use sandpaper to rough up the exterior, and then use an oil-based primer and paint for the best adhesion. If you take enough time to give the paint a good surface to stick to, it will be easier than you'd expect to get good results.
