Author Topic: LCD monitor with RGB to VGA adapter & static image  (Read 1578 times)
mike boss
« on: October 11, 2013, 08:46:26 am »
I have my jamma wired Bad Dudes cabinet set up with a 19" LCD.
I use one of the readily available (on eBay) RGA to VGA adapters.
I've used these before and I'm actually using one with my current Final Fight cabinet.
Anyway, I decided I was going to try and adjust the picture as the Bad Dudes didn't quite 100% fill the screen.
I cycled thru the menu many times, trying different resolutions, and trying to move/enlarge the picture.
At one point the picture was very out of wack. I could not seem to get it back to normal. I powered down and powered on and  the problem still exists.
When the board comes on I see the title screen, then when it goes to the start screen the image becomes static. I can coin-up and hear the game playing blind so I assume the board itself is fine. Just the adapter will now not display.
Anyone had this issue, can I do anything ?
I tired to unplug and plug back in all connections, even tired resetting the board.
Did my many clicks of the menu button screw up the board ?
EDIT - I can upload a short video when I get home.
Thanks all
lilshawn
  • Last login:Yesterday at 07:29:21 pm
Re: LCD monitor with RGB to VGA adapter & static image
« Reply #1 on: October 11, 2013, 01:18:37 pm »
*see other post*
Check your power suppling the board. as i recall, those boards have some pretty hefty requirements for power (5 volts at 2 amps (2000 mA) be sure you can supply at LEAST that much.
DGP
  • Gamer4Life
    • My Toys...
« Reply #2 on: October 11, 2013, 05:59:42 pm »
Have you tried one of the other inputs on the Gonbes board (assuming that is what you are using)?
Jason
mike boss
« Reply #3 on: October 12, 2013, 08:56:15 am »
I did.
It has two VGA outputs, I tried both.
mike boss
« Reply #4 on: October 14, 2013, 12:38:01 pm »
Was the horizontal sync.
Glad it is now fixed.
