Author Topic: RGB Trackball warping?  (Read 945 times)
Todesengel
  • Last login:July 30, 2024, 09:42:08 pm
« on: October 10, 2013, 09:05:15 pm »
I have noticed if I boot up my mame cabinet, play street fighter for a bit, then switch it up to golden tee. The surface part of the trackball that has been sitting on the RGB Led, is super hot and the trackball now catches on the corners of the housing. Is this a bad trackball? Or is this normal? It's a HAPPS 3" RGB Trackball from twistedquarters.
« Last Edit: October 10, 2013, 09:08:58 pm by Todesengel »
BobA
  • What Me Worry?
Re: RGB Trackball warping?
« Reply #1 on: October 10, 2013, 11:12:42 pm »
Sounds like you are driving the LED's too hard.   Try reducing the voltage or increasing the resistance.
Todesengel
« Reply #2 on: October 11, 2013, 12:50:56 pm »
Well, I havent taken it apart yet. From what I can tell it definitely has some LEDS on a circuit board, so I assume it has its own driver as well. It is just straight 12v, that I have tied into a molex and plugged into the 12v molex of my PC. Multi-meter shows 11.93v on the line. Not really sure if dropping the voltage would work in this setup?
  • Last login:Today at 04:28:07 am
« Reply #3 on: October 11, 2013, 05:33:13 pm »
The 12v LEDs should run fine on 5v.
I run 12v LED buttons on 5v for the lower current draw.
