Author Topic: Raspberry Pi and Speakers 5W  (Read 8737 times)
gezy
  • Last login:October 29, 2013, 06:15:29 am
« on: October 09, 2013, 09:04:14 am »
Hi guys,
I will need your help for the audio of my arcade cabinet.
I have a Raspberry Pi with Sanwa buttons connected with KADE.
So now, I want to connect 2 speakers, but I'm not sure how.
Speakers : http://www.arcadeshop.de/Audio-Video-Speaker-5-Watt_323.html
My understanding is that I have to use an amplifier for that, because I can't connect directly to the Raspberry. Am I right ?
Audio amplifier : http://www.arcadeshop.de/Audio-Video-Audio-Amplifier-stereo_767.html
Raspberry Pi -> Audio Amplifier -> Speakers
But I think I will need a power supply for the amplifier...
This one ? : http://www.arcadeshop.de/Power-Supply-Power-Supply-130W-5/12/-5V_338.html
It seems very expensive and immoderate for these little tow speakers...  :o
At least for the power supply.
Thanks for any advice  ;D
  • Last login:November 29, 2025, 04:34:53 pm
Re: Raspberry Pi and Speakers 5W
« Reply #1 on: October 09, 2013, 09:14:08 am »
Check eBay for the "Lepai" mini amplifier. Works a charm.
gezy
gezy
« Reply #4 on: October 09, 2013, 09:22:03 am »
Yeah sounds good !
Many thanks  :applaud:
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
« Reply #5 on: October 09, 2013, 09:42:39 am »
You may need to change the audio output on the Pi as I think it's set to HDMI as default, you can choose one of two audio outputs on RaspberryPi using amixer command. You can use one of three modes: 0=auto, 1=analog, 2=hdmi, like this: sudo amixer cset numid=3
gezy
« Reply #6 on: October 09, 2013, 09:46:06 am »
Ok I will remember this ;)
VoltaTom
  • Last login:November 11, 2018, 09:42:10 pm
Re: Re: Raspberry Pi and Speakers 5W
« Reply #7 on: October 09, 2013, 11:19:10 am »
evilpotatoguy
  • Newbie
  • Last login:October 28, 2013, 05:59:58 pm
« Reply #8 on: October 09, 2013, 02:24:04 pm »
Thanks for the information about the Lepai amp. I'm also using a Pi, so this may be the solution I'm looking for.
