Author Topic: K7000 powers on, display is warped...  (Read 2067 times)
Zunni
  • Last login:March 17, 2014, 04:49:48 pm
« on: October 08, 2013, 11:22:00 am »
Hey guys, I told you I'd post with the next issue,
Any thoughts what this is?
I need to replace the control pots (V. Hold etc) on the main board as they currently are connected to an interface for a different style game board. Could that be all this is?
Note, there is no signal being sent to that display at the time I see this rolling.
grantspain
Re: K7000 powers on, display is warped...
« Reply #1 on: October 08, 2013, 04:07:26 pm »
look like severe vertical foldover but could be a corroded deflection yoke causing it as the pattern looks very similar to one i had the same issue with recently
Zunni
« Reply #2 on: October 08, 2013, 07:25:01 pm »
Thanks for the reply, how can I fix it? Are there any guides online I could follow?
grantspain
« Reply #3 on: October 09, 2013, 03:02:51 am »
not a corroded deflection yoke you can't but you need to prove it first and the only way to do that is to test it on a known good working crt
ed12
« Reply #4 on: October 09, 2013, 12:04:21 pm »
first and foremost
fix them pots and hook them up right
second do not run  that monitor until u do so
U are driving it right out of freq the way u are going,and u run the risk of hortz or vert fauiler,fix the pots first,then do your tests
next time have a signal hooked to it
ed
