Author Topic: Efficient bartop build - loads more pics added!  (Read 12027 times)
bluemini17
  • Last login:June 06, 2014, 10:26:11 am
    • My Youtube Channel
« on: September 30, 2013, 03:05:02 pm »
Hi everyone. First and foremost, what a great forum. I tend to spend most of my time lurking and not a lot of time posting. I have built several arcades since my time of joining byoac in 2009 mainly bartops and a few full size cabs. Like most people, I have a busy life and getting time for our hobby is hard at times. For this reason I have tried to streamline my builds by doing things in logical steps and also reducing the amount of cuts / material wastage.
For this reason I have decided to provide you with an account of my bartop construction in the hope that fellow arcade’rs can learn from my mistakes and make our hobby more enjoyable with what precious hours we have to devote to it. I have made several of these to date, mainly for friends and the odd one or two for fellow arcade nuts.
I hope you enjoy my build. I finished it recently but I am more than open to future suggestions / improvements for my next one.
Im from the UK and for that reason all my measurements will be in mm, my apologies for those that are used to inches.
The Design
I started out with a basic concept in my head. I wanted the machine to be small, light’ish ( how light can you make a lump of wood and metal?) and more importantly efficient with materials. For this reason I chose to negate the marquee and any curved features that would require sanding.
I called into my local diy shop and picked up a sheet of 15mm melamine chipboard.
Once I got home I then marked it out with my template and prepared to cut out the pieces.
Once the first piece was cut I then used it as a template for my router. This enabled me to cut out the second side and end up with a matching pair.
Once I had a match I then made a jig to hold my pieces.
This was made from scrap wood I had lying about. From looking at other builds I noticed the norm was to glue/ screw blocks of wood to the inside and then affix the panels to this. I tried this on my other builds but felt it was cumbersome to get the two sides to line up and a lot of measuring was required. It also meant buying screws that were short and would not protrude out the side of the machine.
I had a eureka moment. I purchased a 15mm router bit and began trying to figure out how I could cut a 15mm grove on the side panels to create a slot. I came up with the router jig. As you can see in the pics, the edge of my router follows a piece of wood of which creates a perfect 15mm grove of which other panels slot into.
With the panels routed I then moved on with the build. The remaining panels such as the cp, the top and the kickplate were measured to fit the groove. I cut the remaining wood into a 312mm wide strip ( 6mm for the groove, 300mm for the screen area, and 6mm for the other groove). The reason for the 300mm width is because a piece of A3 sized Perspex / acrylic is roughly 298mm wide) no cutting required = efficient build.
Once I had my 312mm strip I then cut it into the relevant lengths for the cp, kickplate etc.
I then routed my t-molding slot.
Once this was complete I turned my attention to the screen. It is a standard dell 15inch job, ebay special or what have you. I decased it and then grabbed a piece of leftover 15mm wood. I marked out the four VESA mount holes and a cheap mount was made. I then made several measurements to determine where the screen should be mounted. I then routed the groove. The extra length in the groove allowed me to slide the screen up and down until it was in the correct position.
I then wrapped the entire project in vinyl. I did this to save on having to paint the project.
Once wrapped I then added the t-molding and assembled the machine. This involved no screws and only a small amount of wood glue. The 15mm slot is enough to hold the machine together but some glue was added for reassurance.
With my trusty weights added the machine was left to dry.
Stay tuned for my next installment,
Using friction to fit the bezel, modifying a pc power supply and wiring a 60in1 board with variable sound control
« Last Edit: October 06, 2013, 12:58:23 pm by bluemini17 »
  • Last login:Yesterday at 07:06:30 pm
Re: Efficient bartop build
« Reply #1 on: September 30, 2013, 03:34:00 pm »
Nice and neat. How's the viewing angle on the screen working out?  :cheers:
Almighty
  • Last login:October 28, 2013, 04:42:59 pm
    • Mighty Cade
« Reply #2 on: September 30, 2013, 04:12:55 pm »
looks great! :)
skjerk
  • Last login:February 10, 2016, 05:46:19 pm
  • Been working on my bartop for more than 5 years
« Reply #3 on: September 30, 2013, 05:08:26 pm »
Nice build - I love your router-jig ;D
How did you attach the vinyl without getting air-bubbles?
Cheers!
CC-Arcade bartop. Own design, scratch built. Work in progress.
Yvan256
    • Yvan256
« Reply #4 on: September 30, 2013, 08:32:04 pm »
A CNC-like design without the CN part.  :applaud:
mann0mann
  • Last login:June 25, 2016, 12:31:54 pm
  • Still looking for the right project...
    • My Hobby Store
« Reply #5 on: October 02, 2013, 01:35:40 pm »
Really love this build!  It' looks very comfortable to play on.
And I love the "efficiency" aspect of it. I love marquees but I am drawn to alot of these bartops that don't have them.
I wish I had the routing skills to pull off something similar, I would love to build this myself.
Where's a flat pack kit when you need one!
bluemini17
« Reply #6 on: October 06, 2013, 12:52:15 pm »
Now that the cabinet is drying I can turn my attention to the power supply.
The 60in1 board can be powered by an arcade psu or a computer psu with molex connector. I am using a computer psu. They are very easy to come by. Computers have a low tolerance to voltage levels and thus need new psu’s sometimes. Call into any computer shop and they are giving away their slightly out of range psu’s. Instead of it reading 5v it may read 5.1v, for the 60in1 this is no problem. Go grab one!
If it is an atx psu then you will need to locate the green wire and connect it to any one of the black wires. This will make it stay on permanently. I opened up the case and removed all the wires apart from one molex connector.
With the screen wired in I turned on the machine. As you can see the screen doesn’t fill the bezel completely.
To get an accurate boarder I marked a black dot in each corner.
I then removed the bezel from the cabinet and cut through the protective film to remove the outer edge.
With this complete I then spray painted the bezel with your typical black car paint in a can. Once dried I then removed the remaining screen protector. Look at that sharp edge!
The bezel is a snug fit between the computer screen and the control panel. A small bead of clear silicon was also used for added reassurance.
I then turned my attention to the wiring loom. The 60in1 has the option of two players but I am only building a one player cab. For this reason I decided to make my own loom. I marked the jamma connector and also pin 1 and pin 28.
Looking at the jamma layout I decided what wires I needed.
I ran the wires to the buttons and then secured them with a screw near the jamma connector.
Once I was happy with the wires I then twisted them to form one large wire.
I then set about crimping the buttons and soldering the jamma connector.
The 60in1 also has on board sound so I decided to utilise it rather than hack a pair of speakers and end up with the same 1980’s sound quality. To control the volume I attached a pot (1k value) to the + side of the speaker. The – side was ran back to the 60in1.
With the wiring complete I then closed the machine up and tested the controls, sorry for my delay in posting an update ;)
Almighty
    • Mighty Cade
Re: Efficient bartop build - loads more pics added!
« Reply #7 on: October 06, 2013, 01:03:56 pm »
looks great! :cheers:
Now you only need a scanlines generator, must have in my opinion ;)
bluemini17
« Reply #8 on: October 06, 2013, 01:20:24 pm »
I totally agree! i will be buying one soon! your cab is looking great, not long till its complete
Grab a saw and have a go, as they always say, practice makes perfect.
I peel a small piece of the backing off, stick it to the wood and then slowly pull the remaining backing off while massaging the vinyl with a soft cloth, works a treat.
Its real good. i spent a lot of time trying to get it just right for a mixture of playing the machine on the kitchen worktop, on the table and also on the floor.
Thanks Yvan, if only I knew someone who had a cnc I could use ;) keep up the great work!
« Reply #9 on: October 06, 2013, 02:53:36 pm »
Nice work!  :cheers:
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #10 on: October 07, 2013, 11:19:41 am »
Wow, I like this bartop a lot !
 :applaud: :applaud: :applaud:
Wonder if you would let us post pics of your beautiful build at Bartopmania... :angel:
« Last Edit: October 07, 2013, 11:27:32 am by TheDude »
« Reply #11 on: October 07, 2013, 11:25:08 am »
Your ideas for prepping and painting the bezel was genius! Taking notes!!
a1pharm
« Reply #12 on: October 07, 2013, 05:53:04 pm »
+1
I haven't seen someone do it like this before.  I may steal this idea...
Overall, great build, very tight.
Cheers!
CoryBee
  • Bopity Boopy
« Reply #13 on: October 07, 2013, 07:18:17 pm »
I don't get it. What is so special about the bezel paintjob? I do almost exactly the same thing. Mark with a pen where the screen is on the acrylic, on the other side I remove all of the protective cover and put masking tape in a line adjacent to the marks on the other side and fill center with something to cover like paper, paint edges and remove.
I use to leave the center film on but when the paint drys it tends to pull the protective film up a bit and leaves little splotches of paint.
« Reply #14 on: October 07, 2013, 07:20:50 pm »
 :hissy
kujina
  • Last login:November 04, 2021, 12:07:40 pm
« Reply #15 on: October 08, 2013, 08:53:35 pm »
Nice build, can you recommend some vinyl to me, I need it for a control panel.
bluemini17
« Reply #16 on: October 09, 2013, 02:20:01 pm »
whoop de do.....
Just messing, two minds think alike and all that jazz.
I think the reason why other users are commenting is because the process has not be thoroughly documented on the forum. perhaps a tutorial from your good self would cure this, particularly the added stage of masking the bezel.
The reason why i used the existing bezel protection was to reduce the chances of dirt ingress on the piece before paint.
bluemini17
« Reply #17 on: October 09, 2013, 02:21:51 pm »
Of course you can. Would you be so kind to post the link on this page if you do? I have videos of all my bartop builds on youtube if you want to take a look
http://www.youtube.com/user/bluemini17
« Last Edit: October 09, 2013, 02:33:45 pm by bluemini17 »
bluemini17
« Reply #18 on: October 09, 2013, 02:27:28 pm »
I bought mine from ebay. my only advice I would have is to go for a gloss or textured one. the matt black I have used tends to show finger prints, especially if you have just eaten something greasy, crisps etc
a1pharm
« Reply #19 on: October 09, 2013, 03:44:48 pm »
I have glossy vinyl on a recent bartop, and that shows fingerprints as well.  The laminated on my full sized cab shows NO fingerprints.
« Reply #20 on: October 09, 2013, 09:24:43 pm »
Very clean build! I like the absence of a marquee! :applaud:
bluemini17
« Reply #21 on: October 10, 2013, 04:33:45 pm »
Thanks dude, i wasn't sure about the lack of marquee at first but i think the design lends its self well to the minimalist look now that it is finnished
rablack97
« Reply #22 on: October 10, 2013, 05:44:53 pm »
whoop de do.....
Ahemm,
http://forum.arcadecontrols.com/index.php/topic,119435.40.html
3rd video down......
Everyone has there own variations, I mask and paint all of my bezels the same way as well.
Regardless,  Awesome kickass build man, I second the no marquee rave, very clean.... :applaud:
rablack97
« Reply #23 on: October 10, 2013, 05:48:15 pm »
Oh yeah hit-up craftymech and get you some scanlines on that thing  :applaud:
http://forum.arcadecontrols.com/index.php/topic,129344.msg1322747.html#msg1322747
bluemini17
« Reply #24 on: October 12, 2013, 09:55:04 am »
Ahemm,
Amazing vid mate! The spray paint gives a perfect result every time  :cheers:
TheDude
    • BARTOPMANIA
« Reply #25 on: October 14, 2013, 07:23:36 am »
Will do; Thanks a bunch !
Link to thread : http://bartopmania.com/index.php?t=msg&th=557&start=0&
« Last Edit: October 14, 2013, 07:38:47 am by TheDude »
rablack97
« Reply #26 on: October 14, 2013, 09:06:01 am »
What did you use to polish the t-molding?
« Reply #27 on: October 14, 2013, 09:59:44 am »
Ok, this is the second time I've seen this little trick used. The first time was during a "John's Arcade" video. Is this common when dealing with Jamma boards? Does everybody write "Parts Side" on the connector before redoing it?
Source: I'm the dummy who'd probably just cut and paste a side at a time, giving little thought to what was what.
