Author Topic: Six in one JAMMA harness  (Read 4572 times)
klindsay
  • Last login:July 22, 2020, 01:48:16 pm
« on: September 28, 2013, 04:41:35 pm »
I want to buy a 6 in 1 JAMMA harness for all my Golden Tee boards (3D, 97, 98, 99, 2K and Classic).
My problem is that each board has a plug for the trackball. I don't know of any 6 in 1 trackball harnesses. Does anybody know if splicing 6 harnesses together would work or can anybody successfully do it for me?
paigeoliver
  • Awesome face!
Re: Six in one JAMMA harness
« Reply #1 on: September 28, 2013, 07:41:43 pm »
You could mod your boards to make the trackball wiring go over the jamma edge connector, that is probably what I would do.
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« Reply #2 on: September 29, 2013, 11:00:37 am »
I did this with lightguns and it worked great
klindsay
« Reply #3 on: September 29, 2013, 01:03:47 pm »
Do you mean you spliced wires or you modded the boards?
I don't have really any experience doing this sort of stuff. How can I mod the boards to do that?
paigeoliver
  • Awesome face!
« Reply #4 on: September 29, 2013, 07:04:38 pm »
You look at the edge of the boardset and cut the 4 traces that are normally used for the trackball control on the jamma standard. We are just cutting them as a safety measure, they should just terminate but for all I know Incredible Technologies has them connected to ground or something. Then you take your little trackball connecting harness and solder the wires to the edge connector in a manner that you can still plug the board into the jamma harness. Now the trackball connection goes over the the jamma harness instead of an extra connector. Then coming off your Jamma switcher you just run the wires for the spots you used to the trackball. No nasty wire splices running to the trackball and no need to worry about weirdness because you are feeding voltage back to your other boards over the spliced trackball connections.
