Author Topic: help networking in DOS  (Read 1302 times)
dphirschler
  • Last login:February 10, 2021, 10:32:54 am
    • dphirschler homepage
« on: November 18, 2003, 04:59:09 pm »
I have a DOS only cab and I want to add network support.  Where do I start?  My home network is DHCP.
Darryl
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
Re:help networking in DOS
« Reply #1 on: November 18, 2003, 11:15:22 pm »
  It's a bit tricky.  Look around on the 'net, there are a few tutorial sites out there.  You basically have to do manually what windows 3.1 did automatically.  If you're comfortable with messing around in dos it shouldn't be too bad, but if you're not you're in trouble.  =)
  Here are a couple of links to get you started...
  http://www.wown.com/j_helmig/dosclflp.htm
  http://h18000.www1.hp.com/support/files/proworkstation/us/locoscat/8_58.html
  http://www.hindu.com/2003/09/29/stories/2003092900010200.htm
  Good luck!
Jaymz
  • Last login:April 19, 2004, 12:28:26 pm
« Reply #2 on: November 20, 2003, 01:17:19 am »
dphirschler
« Reply #3 on: November 20, 2003, 04:12:23 pm »
Thanks to both of you.  Those are great websites for DOS-only systems.  I'll let you know my progress setting up the network.
Darryl
