Author Topic: Dragon's Lair II Blu-Ray in Daphne  (Read 6770 times)
benll64
  • Last login:February 13, 2026, 01:35:49 am
« on: September 22, 2013, 11:01:31 pm »
So, after a lot of trial and error with a ton of different software utilities, I finally managed to get the video files off of the DLII Blu-Ray converted and working in Daphne.
For anyone wondering about the difference in quality, here are two comparison pics.
The Laserdisc rip provided by Daphne:
And the HD Blu-Ray rip:
The HD image is much brighter, cleaner, and with more accurate colors. Worth the effort in my opinion. The Daphne boards claim that the LD rip is the best quality out there, but I have to disagree.
If anyone's interested, here's the 5 steps I followed. This assumes you have a working Daphne DL2 installation.
1) Rip all of the .m2ts files inside the /BDMV/STREAM/ folder of the blu-ray disc to the hard drive. I used DVD-Fab, but MakeMKV and others can do this too.
2) Open up your Daphne folder with the laserdisc-rip vido files, alongside the folder with you new HD files. If you set your view to "Thumbnails" you can tell at a glance how to match them up. You need to manually rename each of the HD files to the same name as the ones in the Daphne folder. This sounds awful, but it only took a couple of hours total.
2) Use Handbrake, along with a separate tool called BatchEncoder for Handbrake, to convert the ripped files. This part was the trickiest to figure out.
Use the following settings in Handbrake:
File type .MKV; video codec MPEG-2; framerate Same as Source; Avg Bitrate 8000K; audio codec Vorbis; audio bitrate 192; audio samplerate 44.1.
Also, note that the HD video files come in both 4:3 (with black bars) and 16:9 (stretched with some loss of image) aspect ratios, but both are in the full 1920x1080 resolution. For best results in Daphne, you want to crop 240 pixels off the left and right side to eliminate the black bars, and you want to have Handbrake resize the (now 1440x1080) down to 640x480.
3) Use a demuxing program to split your new .MKV files into a matched pair of MPG/OGG files. I used MKVExtractGUI2, but there are others that people have used.
4) Use Bulk Rename Utility to change the .MPG extension to the .M2V extension so Daphne can play it.
There's probably other ways to do this, but I thought I'd share what worked for me. It really makes playing it on an arcade monitor a lot more fun.
marioxb
  • Last login:January 13, 2026, 06:44:24 pm
Re: Dragon's Lair II Blu-Ray in Daphne
« Reply #1 on: September 23, 2013, 04:45:32 pm »
Looks sweet to me! I'll have to look into this!
matsadona
« Reply #2 on: September 24, 2013, 08:37:00 am »
Thanks for sharing your hard work  :cheers:
marioxb
« Reply #3 on: September 24, 2013, 09:24:46 am »
Guess I need a Blu-Ray drive.
benll64
« Reply #4 on: September 24, 2013, 03:24:10 pm »
Sure, no problem.
I'm usually benefitting from someone else taking the time to spell things out on here, so I thought it was my turn.
Giddygoon
  • Last login:March 22, 2022, 04:13:04 am
« Reply #5 on: January 12, 2014, 09:58:39 am »
Hi there,
Amazing you perfected something I've have been trying to archive for sometime, I already have HD versions of Dragons Lair and Space Ace running in both an Atari Dragons Lair cab and the other in a Space 91 cab but DL 2 was always tricky to convert because of the 16.9 aspect ratio...
I was wondering if you ever found a better Space Ace 91 transfer... I have one but it's suffers from interlace issues..
I was wondering if BENLL64 could PM me back as I have tried but I get an error...
If you can give me any info please PM
Thanks again John. ( Giddygoon ) from Dragon's Lair Fans Forum and Jamma+
Hoopz
  • Intellivision Rocks!
« Reply #6 on: January 12, 2014, 10:58:36 am »
You can"t send a PM when you have "Newbie" status.  Post a few more times and it'll go away...
Hoopz
« Reply #7 on: January 12, 2014, 11:02:25 am »
I just sent him a PM for you in hopes he sees your question more quickly.
Giddygoon
« Reply #8 on: January 12, 2014, 04:49:55 pm »
Much appreciated Hoopz
neoraizo
  • Last login:November 21, 2015, 05:09:19 pm
« Reply #9 on: November 12, 2015, 02:50:47 am »
As Dragon's Lair II fan, I owned Blu-Ray and follow your tutorial. Work great ! Thank you very much. Daphne run 1440x1080 DLII. Perfect !  :applaud:
I create batch file to rename automatically video from BR. Let me know if you want it.
I tried the same with 1920x1080 version to run Daphne, but unfortunately I don't succeed to set the resolution to 1080p only 1024x768. I don't understand why  ???. Could you help me ? Thank you.
Avalonhaze
  • Last login:December 04, 2015, 01:56:03 pm
« Reply #10 on: November 13, 2015, 05:24:56 am »
Interesting, I have been considering something like this for my copy of Mad McCree. The DVD video is superior to the CD-ROM version but I'm not sure whether the hit boxes will translate.
  • Last login:February 15, 2026, 01:44:40 pm
« Reply #11 on: November 13, 2015, 01:30:17 pm »
Are you talking about Singe?
That's a good question actually.  I'm not sure if the hit boxes are relative or absolute.  I would guess relative.
