Author Topic: Smash TV artworks (Freehand format) ready to download  (Read 4435 times)
aioros
  • Last login:August 19, 2014, 07:40:45 am
  • Love designing arcade artworks
« on: September 20, 2013, 05:11:25 am »
Hi everybody,
My name is Daniel and I'm a spanish arcade fan. I love everything related with the arcade artwork design and recently I've recreated the Smash TV artworks (you can follow the entire process here).
In order to vectorize them, these were the source files I've used:
Code: [Select]
Marquee --->Arcadeartlibrary
Side Arts and bezel---> Flyer from arcarc.xmission.com
25'' CPO---> A photograph taken by Mojave James and shared on Flickr
19'' CPO---> Once finished the 25'' version it was really easy to adapt to the 19'' cabinet
Instructions and identity card---> Photographs taken by Vongoosewink, Arcade Museum Forum
They can be used as they are right now to build a new cabinet, for example, but if you want to make them 100% accurate you may need to do a measument check and color correction to match the original one. Since I don't own this cabinet, I'm not able to do it  :'(
They are available to download from Vectorlib (Thanks Zorg ;)), Arcade Art library and Arcade Forever Forum.
Enjoy them!! ;)
Regards :)
Help me!!! I see vectors everywhere!!
TopJimmyCooks
  • Last login:March 01, 2026, 03:28:53 pm
Re: Smash TV artworks (Freehand format) ready to download
« Reply #1 on: September 20, 2013, 08:09:13 am »
looks really nice! Thanks.
  • Last login:Today at 01:53:38 am
« Reply #2 on: September 20, 2013, 06:52:26 pm »
Muchisimas gracias y bienvenido, Daniel. :applaud:
Well Fed Games
  • Delicious!
« Reply #3 on: September 20, 2013, 08:13:58 pm »
Thank you! Excellent work!
edit: I don't suppose you could upload those in .ai format?
« Last Edit: September 20, 2013, 08:30:28 pm by Well Fed Games »
« Reply #4 on: September 20, 2013, 08:53:20 pm »
From what I just read, FreehandMX Ver. 11 files can be opened in Adobe Illustrator, but converting them to a more common file type would be a great idea for those of us using Inkscape, etc.   ;D
Well Fed Games
  • Delicious!
« Reply #5 on: September 20, 2013, 10:42:07 pm »
Yeah, I tried in CS2 but no luck opening the .FH11 files... but I am not particuarly experienced with importing things into Illustrator, might be a case of user error.
aioros
« Reply #6 on: September 21, 2013, 07:21:13 am »
Macromedia Freehand MX (ver.11) files are not supported by Illustrator CS2, you need to convert them to Freehand 9 version :(.  Anyway, I donīt recomend it. I had some bad experiences in the past about handling files converted into many different formats (missing gradient sections, uneditable elements, moved shapes, weird colors, etc).
Take a look at the video labelled as 2. Migrating Existing FreeHand Content on this webpage and you will understand what I mean.
I know that having this files in Freehand format is a little bit annoying, sorry  :embarassed:, but I've tried to migrate to Illustrator a lot of times without any success. As Freehand is really easy to use, I feel really confortable working with it (I'm very lazy, I know :D).  When I want to edit the final file to add some effects I just drag and drop the entire object into Photoshop and there it is, ready to the next step  ::).
Another option would be uploading 300dpi images. I can post you the links, if you prefer ;)
Edit:
I've just found this funny video: Freehand vs Illustrator.
 :D :D :D :D ;D
« Last Edit: September 21, 2013, 07:34:47 am by aioros »
Well Fed Games
  • Delicious!
« Reply #7 on: September 21, 2013, 07:34:00 pm »
Na, that is cool, thanks for checking into it!
