Author Topic: Controlling Q-Bert with my U360 Stick using UltraMap  (Read 2806 times)
EMDB
  • Project RetroCade
« on: September 19, 2013, 04:33:06 pm »
I had some problems controlling Q-bert with my U360 stick. I used the 4-Way, Diagonals Only map which came with the installation of UltraMap. Q-Bert kept jumping off the maze. Studying the map and using the keyboard's arrow keys I finaly noticed why: Pushing the stick to the top right position should send an up-key but using the '4-Way, Diagonals Only' map it sends an Up AND a Right. So in facts it's an 8-way map controlling an 4-way game. Maybe if you use the analog mode of the stick the build in re-mapping of MAME fixes this but I use it the digital way (connecting the U360 Stick with the harnas to my iPAC2).
What you want to achieve is an 4-way 45 degrees rotated stick. I changed the map accordingly and now Q-Bert finally does what I want him to  :applaud:
I think Andy should change the name of ' 4-Way, Diagonals Only' in the UltraMap installation.  ::)  It's very confusing and even wrong. Maybe he should add my map calling it something like '4-Way, Rotated 45 degrees Clockwise'.
« Last Edit: September 19, 2013, 06:21:41 pm by EMDB »
lindart
  • Last login:January 07, 2014, 07:04:36 pm
    • The Place To Be
Re: Controlling Q-Bert with my U360 Stick using UltraMap
« Reply #1 on: October 15, 2013, 07:22:34 am »
I was experiencing the same problem, and this really helped... Thank You! He should just call it the Q-Bert Setting.
TopJimmyCooks
  • Online Online
  • Last login:Today at 03:25:31 pm
« Reply #2 on: October 15, 2013, 08:25:03 am »
It is confusing, I went through a similar process a few years back.  I fixed it by changing the inputs in mame to work with the original diagonals only map I think.
EMDB
  • Project RetroCade
« Reply #3 on: October 15, 2013, 09:47:39 am »
But than Q-Bert moves top-right when you move your stick up!?
