Author Topic: Playing Tron - PC Joystick?  (Read 1087 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: September 18, 2013, 09:08:04 am »
In the process of building a new CP, I am going to put in a spinner for Arkonoid, and thought of also using it for Tron.  I don't want to go to the extreme of obtaining an original Tron joystick and mounting it on my CP, so I was thinking if anyone here has used a USB or wireless PC joystick/flight stick for playing games like Tron or Gorf.
I'm thinking that for such games, I'd be be able to suction cup, or somehow temporary secure the joystick to my Control Panel and remove when I"m done.
Not sure if there'll be any configuration and conflict issues: how would the spinner map in unison with the joystick
Am I mad, or is this completely sane? :)
paigeoliver
  • Awesome face!
Re: Playing Tron - PC Joystick?
« Reply #1 on: September 18, 2013, 11:23:24 am »
Well, you are only half mad.
You DON'T want a PC flight stick. Those are analog and Tron is quite digital.
The big stick isn't really required for Gorf and the cocktail one didn't even have it.
You are better off getting any actual arcade top fire stick for tron than you are a PC flightstick. However it doesn't play RIGHT without the original stick, which is an 8-way stick with guides in a shape that kept most of the range to the primary directions and not the diagonals.
If you want something to pull out and put on top of the panel then you want this.
http://www.ebay.com/itm/Vintage-Wico-Red-Bat-Command-Control-Joystick-Tested-Atari-2600-Commodore-64-/141062954444?pt=US_Video_Game_Controllers&hash=item20d801ddcc
It is 8-way, made by Wico and easily wires up to the encoder you are already using.
However depending on your spinner location you could just swap out one of your sticks for one with a button on the top and solve all your problems (other than the basic fact that Tron isn't that fun once it comes out of the cool cabinet with all the blacklights and such).
Richardgregory
« Reply #2 on: September 18, 2013, 12:58:08 pm »
Paigeoliver: thanks for the link!  I might just do that.
You're right......I played Tron recently (orginal cab), and with all the lights and stuff, it won't be the same.  Oh well, something is better than nothing....
« Last Edit: September 18, 2013, 01:00:15 pm by Richardgregory »
