Author Topic: WG K7400 Yoke readings  (Read 3232 times)
Gamemaster86
  • Last login:July 20, 2024, 10:21:23 am
  • Proud owner of A Sammy Atomiswave :-)
« on: September 13, 2013, 03:36:51 pm »
Hi would anybody who has a Wells Gardner K7400 chassis and matching tube, be able to check their yoke readings for me?
It;s just I have a suspicion theres something wrong with mine. I'm getting 01.1 on Horizontal and 06.2 on Vertical but i'm having geometry issues so trying to track i down.
Would really help me out.
For reference the Sticker on both the chassis and tube is WG 2036840
Thanks in advance
ed12
Re: WG K7400 Yoke readings
« Reply #1 on: September 13, 2013, 03:43:57 pm »
Gamemaster86
on the yoke should be a # or give me the exact picture tube # 26" 27" 29"?
so a61-xx-xx-xxxx or a63/a68 or by tybe type
rca/zentih etc and size
ed
Gamemaster86
« Reply #2 on: September 13, 2013, 03:51:27 pm »
Sorry is a 25"
Picture below
ed12
« Reply #3 on: September 13, 2013, 04:58:26 pm »
my list
25"
phillps a63 horz = 1.2 ohm vert 7.7 ohm
phillips a63 horz = 19.4 ohm vert 7.7 ohm
chk my list
thk-u rickn
ed
ed12
« Reply #4 on: September 13, 2013, 04:59:49 pm »
btw yours is a phillips
ed
Gamemaster86
« Reply #5 on: September 13, 2013, 06:04:46 pm »
Hmmm my reading are pretty worrying....
Green and Yellow plug (Vertical I think) I got 06.7 and Red and Blue plug (Horizontal I think) I got 01.1
I took the readings by putting the probes into each of the 2 sockets with the power off
ed12
« Reply #6 on: September 13, 2013, 08:39:19 pm »
for futher refernce
from right to left on the coloums
Lh=millhenres  Rh=restinace :horz:
Lv=millhenres  Rv=restinace :vert:
ed
p.s it is not a sony tube
but just in case i am wrong ?
then it would be a flat-planer style tube
Gamemaster86
« Reply #7 on: September 14, 2013, 07:48:09 pm »
No definitely a Phillips tube and it has curved glass too.
ed12
« Reply #8 on: September 14, 2013, 09:11:07 pm »
ok off hand are u measuring ohm's olny ?
if so un-plug the yoke
and do the measure
as my list covers both
:mh: and :res:
now make sure as u were asked  in the other thread chk the caps
as 1 b+ is getting loaded
now with the horz back in shape ?
u want to find the :vert: problem
just so happen's thats the feed line to to vert output ic.
there is a cap in that circuit that will tend to go a bit south and do the exact problem u are having,but without an esr meter u will just have to plug away>as it is said<
and it will be a small cap 1mf/2.2mf/4.7 some where in that range
ed
p.s thk-u i thought it was a philips
use the rca #'s as rca built the tube
