Author Topic: Cab friendly emulators for consoles?  (Read 4639 times)
MacGyver2
  • Last login:January 01, 2014, 09:41:56 am
« on: September 08, 2013, 01:49:04 pm »
I've just installed about every Genesis, SNES, NES, 2600,  and none of them (barring 1) could be set to Exit with the ESC key, most won't launch fullscreen from the start, some won't launch a game ran as an argument.   MESS is the closest but requires a bizarre amount of file renaming to work with anything, same with HazeMD.
I have searched the forum, but the words "console, arcade, cabinet, and emulator" show up in EVERYTHING.
Can someone share a list of some they have discovered (with version numbers if possible).  I'm looking for pretty much all of the old console emulators that can work smoothly in my cabinet (running 32-bit Win 7).
Here are some of the ones that I've tried so far:
adamem.zip
Ages030a.7z
fceux-2.2.1-win32.zip
Fusion364-738.zip
Fusion364.zip
gens+00961.zip
gens-win32-bin-2.14.zip
Gens32_Surreal_v1_86_HD.zip
gensplusrewind-1.0-win32-mk2k.zip
hazemd014a.rar
higan_v093-32bit.7z
higan_v093-64bit.7z
jnes_1_1.zip
mess0149b.exe
mupen64plus-bundle-win32-2.0.zip
Nestopia140bin.zip
nostalgia5_setup.exe
PCAEWin_2.7.zip
pcsxr-1.9.93-win32.zip
Project64_2.0.zip
Regen0972-1831.zip
retrocopy_win32_0960.exe
snes9x-1.53-win32.zip
snes9x-1.53-x64.zip
snesgt0218e.zip
Stella-3.9.2-windows.zip
stella-snapshots-20130626.zip
Surreal64
TurboEngine03.zip
vcol211a.zip
VisualBoyAdvanceM1022.7z
VisualBoyAdvanceM1149.7z
Any help?
« Last Edit: September 08, 2013, 01:50:51 pm by MacGyver2 »
mike boss
Re: Cab friendly emulators for consoles?
« Reply #1 on: September 09, 2013, 08:05:58 am »
I wish a master list of this nature did exist somewhere.
I, like you had to search high and low.
I have a few set up on my Mario MAME using MaLa.
I've had issues where some emulators don't let you  change the keys to match that of the ipac.
(that is perhaps my biggest issue)
However I've got some NES, SNES, etc emulators running.
I'll try and get the info up asap.
I also think that a newer (newest) version of N64 emulator lets you configure all keys.
edekoning
  • Last login:December 03, 2025, 04:21:00 pm
« Reply #2 on: September 09, 2013, 09:21:58 am »
I just started with adding emus to my cab, where I use Mala and standard Mame key-bindings, so all emus need to play nice with that.
The Kega Fusion v3.64 that you listed works great with a cabinet, as it has decent command line support:
Fusion <rom> [console] [country ] [-fullscreen]
console = -sms, -gg, -gen, -md, -32x, -scd, -mcd
country = -usa -jap -eur -auto
It can also be configured to exit upon pressing the ESC key. Setting up the key-bindings was kinda annoying as binding ALT from within the GUI doesn't really work. So I had to manually edit an ini file. With Kega Fusion you have most classic Sega consoles covered.
For SNES I am currently trying out Snes9x v1.53. Some things I ran into were that it will only startup fullscreen if it was running fullscreen the last time you closed it. Also you can only exit through Alt+F4. But with Mala I can just configure Esc as a Hotkey to exit the emulator. Setting up the key-bindings was easy. I wanted to try Higan v0.93 as it is supposed to be a highly accurate emulator, but there is no documentation, and apparently no command line. There is also RetroArch v0.9.9, but it either complained about missing DLLs after I installed it, or it showed a GUI and stopped responding.
Next step for me is selecting a NES emulator.
« Last Edit: September 09, 2013, 09:23:41 am by edekoning »
rpgposer
  • Last login:August 31, 2018, 11:46:12 am
  • PSO lover.
« Reply #3 on: September 25, 2013, 08:36:11 am »
I use mednafen for nes/gba/gb/pce.  Greate command line based multi emu.
Never met a game I won't keep.
thomas_surles
« Reply #4 on: October 09, 2013, 03:14:28 pm »
I use maximus arcade for my front end, and it exits the emulators automatically when you press the esc key (or whatever key you set it too).
blacketj
  • Last login:August 29, 2018, 01:00:07 am
« Reply #5 on: October 09, 2013, 06:29:31 pm »
Hyperspin as well.
