Author Topic: Hiscore saving issue  (Read 3130 times)
Rodman
  • Last login:January 07, 2015, 02:48:58 am
  • Built my first own arcade controls long long ago!
« on: September 07, 2013, 01:49:00 am »
As far as i know the latest GM release already has the hiscore patch applied/built in...
In my setup no hiscores are saved ... :cry:
Tested on pacman and Xain'd Sleena.
Please help!
-= Real control builders dont use J-Pacs =-
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: Hiscore saving issue
« Reply #1 on: September 07, 2013, 05:37:58 am »
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
in mame.ini
  • Last login:Today at 03:21:24 am
« Reply #2 on: September 07, 2013, 08:14:01 am »
Hi Rodman,
Make sure to place the hiscore.dat *inside* the \hi folder.
Rodman
« Reply #3 on: September 08, 2013, 11:28:50 am »
.... .dat was NOT in /hi dir ....
Another great victory against the machine by mighty mighty Calamity!
Thx again Calamity and Sledge - you keep the spirit alive  :notworthy:
Sledge
« Reply #4 on: September 08, 2013, 06:58:53 pm »
Yeah sorry.. I had assumed you had put it in there :)
Rodman
« Reply #5 on: September 09, 2013, 03:21:24 pm »
No - rookie mistake over here...
Assumed the mamedir where it was located is the right place...
As the highscorefix is built in maybe the .dat locatin could be corrected for the next GM release..
However in my setup now even highscore saving works flawlessly..
Regards,
R.
