Author Topic: Advance Mame and Menu with Eygo 19" in DOS  (Read 2422 times)
Brent Strache
« on: March 30, 2002, 07:30:05 pm »
Hello all,  I am so close to finishing up my cabinet, however I am having some issues with my video settings.  I get that vertical line on my eygo monitor on the left side when swiching to games.   I can move it out of the way with the monitor's controls, however then the screen is not aligned for other games and Advance Menu.  I believe it is happening when Advance Mame switches video modes.  I believe I need 640 x 480 all the time with some sort of streching.   I have gone over all of the .txt files and could not find anything to help me out.  The answer is probably there, I am just having problem understanding it.  I have my monitor specifications and I will list the below.  Can someone please help me out?  I am so close.  I can already tell this project was well worth the time and can't wait.  Thank you all in advance.
They are Eygo 19" arcade monitors.
Specs:
Power Supply
Switch mode power supply
Dual AC input range
Jumper selectable
No isolation transformer required
Input Signal
Video - RGB analog, positive, 0.7 Vp-p.
Impedance - 75 ohms, terminated.
Rise Time - less than 25 nanoseconds.
Bandwidth - DC to 25 MHz (at - 3dB), mode 3.
Resolution - Model
1. 640 x 350 (70Hz refresh)
2. 640 x 400 (70Hz refresh)
3. 640 x 480 (60Hz refresh)
Sync. - TTL, positive or negative. Monitor circuitry
will
automatically determine and adjust for VGA Horizontal
Scan - Frequency 31.5KHz nominal
Capture range-30.5~32.5KHz
Active video - full width display of video
signals with active video from 25 to 28usec.
Linearity - plus or minus 5%
Vertical Scan - Frequency 60/70Hz
Capture range 47~85Hz
Picture Size Regulation
2%
Geometric Distortion
plus or minus 1.5% (max)
Environmental Conditions
Temperature 100 ~ 550C
Humidity 10~90%, no condensation
High Voltage
13"=23KV, 20"=25KV, with integral X-radiation
Shut-down protection
Degaussing
Automatic, operating at beginning of each power-up
cycle, provided the monitor has been turned off for
at least 20 minutes.
