Author Topic: WG 25" K7400 curved edge problem  (Read 9176 times)
Gamemaster86
  • Last login:July 20, 2024, 10:21:23 am
  • Proud owner of A Sammy Atomiswave :-)
« on: September 03, 2013, 05:07:54 am »
Hi,
I'm after some advice on how to fix an issue with my monitor. Both the left and right edges towards the middle of the edge, are curved. Meaning to get to a stage where I don't see it I have to stretch the screen and lose part of it. Has anybody seen this issue before and fixed it? I have tried adjusting the keystone / pincushion control on the back but to no avail.
Here are pictures of the issue.
Thanks for looking.
Gamemaster86
Re: WG 25" K7400 curved edge problem
« Reply #1 on: September 06, 2013, 05:51:27 am »
Another thing I thought was odd is that the 25" K7400 chassis doesn't mention having a pincushion adjustment board in the manual - could this have been a late addon?
Also if I reduce the H-Size all the way down it turn the whole thing inwards to create a pincushion.
Anybody seen a problem like this before?
Gamemaster86
Re: WG 25" K7400 curved vertical edges problem
« Reply #2 on: September 09, 2013, 01:03:33 pm »
I've now found it's not just the edges of the pictures that have bent lines, but also edges of windows etc. It's shown better in the pics.
Can anybody recommend a potential fix or repairer located in England?
ed12
« Reply #3 on: September 09, 2013, 01:47:12 pm »
yes
a few things will cause that problem
poor power requlation,or a leaky horz coupler cap,or your yoke is going south
u must chk the first 2 first
the small add in board was put in for certian game use
as a rule i remove them,as my games run 1 res.
ed
Gamemaster86
« Reply #4 on: September 09, 2013, 02:45:32 pm »
yes
ed
Thanks for the reply  :)
Sorry to sound like a newb but how would I go about checking the first two?
ed12
« Reply #5 on: September 09, 2013, 03:22:55 pm »
a few things first
the newb is a no nomer here :)
second do u own a mulitmeter ?
third do u have the service manual ?
if so look for the :test: points
and meter them
they have to be within a 10%  range
so this would equal 165-10%=about 163
much like that
start there
ed
Gamemaster86
« Reply #6 on: September 09, 2013, 05:29:21 pm »
Hi,
Yes I have the manual and the schematic links are here http://www.wellsgardner.com/pdf/Schematics/K7400_25_inch.pdf and here http://www.wellsgardner.com/pdf/Spec/K7400_25.pdf
The trouble is I can't see any points called :test: any idea where and which points I'd need to check?
I presume I'd be measuring resistance?
ed12
« Reply #7 on: September 09, 2013, 07:45:36 pm »
hi
in the manuals they are listed as tp101/102/103 etc
the point here is >tp<
and it will state dc or ac volts
make sure as i explained they are within range
ed
Gamemaster86
« Reply #8 on: September 10, 2013, 05:58:16 am »
Ok, so I can see a few TP 'test points' on the schematic but can't see any voltages next or near to a test point. Take for instance tp 103 and tp 104 located in square 6B, it doesn't have a voltage near them.
  • Last login:Today at 06:22:50 pm
« Reply #9 on: September 10, 2013, 11:05:28 am »
sigh...  :-\ you go to the bother of linking the schematic and spec sheet, but glaze over the voltage reference charts right next to them?!
http://www.wellsgardner.com/pdf/voltage/K7400_K7500.pdf
Gamemaster86
« Reply #10 on: September 10, 2013, 11:07:27 am »
Apologies, this list wasn't in my collection.
Thanks for posting.
« Reply #11 on: September 10, 2013, 11:13:40 am »
Grab everything for your monitor and read it, especially the "service manual" (k7500/u5000 is basically the same chassis). It has a step by step for just about every adjustment on there. It even goes as far as how to adjust the convergence. (which not a lot of instructions exist for that as it was a manufacturer done thing, not to be done out in the field.) Theory of operation...best way to learn how things work is by learning the theory of operation. once you know that, you can easily troubleshoot issues.
Best manual ever.  :applaud:
Gamemaster86
« Reply #12 on: September 10, 2013, 11:43:14 am »
Looks like I have some reading to do.
Will report back if I come up with anything.
ed12
« Reply #13 on: September 10, 2013, 12:31:50 pm »
hi
there is 4 test points of interest
they are all dc
tp202
tp203
tp204
tp205
hone in on them
ed
Gamemaster86
« Reply #14 on: September 10, 2013, 07:13:24 pm »
Ok so after some more tested i'm pretty sure it's not the yoke as i've tuned both the static and dynamic convergence and still have the bent lines.
Will now test the points mentioned. A few more questions and I should be able to get going :
1. I am presuming I will need to have power to the chassis in order to test the voltages?
2. I'm guessing that the points will be underneath so thats means discharging the tube and removing that correct?
3. Lastly am I right in saying that to check the voltages I test from the TP to the next black dot next to it on the diagram?
Thanks for the assistance.
« Last Edit: September 10, 2013, 07:24:51 pm by Gamemaster86 »
ed12
« Reply #15 on: September 10, 2013, 08:30:24 pm »
a tp is always refed to ground
u should beable to tell the tp from the top of the chassic
just look the schematic over and see where it comes from
ie r101 lets say hook's to tp101 and carrys on into the circuit
u can test it right there
and so on
btw conv dynamic and or static will not tell if the yoke is going south
do the tp tests first,then get back to us
ed
« Reply #16 on: September 11, 2013, 10:27:38 am »
no, it should have a tiny little post soldered into the board. some didn't though so you'll just have to follow the schematic to the next part...capacitor or diode or resistor....something with a bare leg you can probe.
if you are skittish about poking around 300+ volts then get a wire with some alligator clips on it and clamp it on there and power it up and take your reading with it all hooked up.
Gamemaster86
« Reply #17 on: September 11, 2013, 10:35:44 am »
Great tips, thanks guys  :)
Will report back with my findings.
Gamemaster86
« Reply #18 on: September 11, 2013, 01:52:01 pm »
Luckily I have the tiny soldered posts which made it easy to connect the probe. Even with the schematics finding the points wasn't easy though.
Ok values are as follows :
TP202 = 124.3 V  ------Listed Typical Voltage = 117.20 V
TP203 = 148.0 V  ------Listed Typical Voltage = 152.00 V
TP204 = 15.46 V  ------Listed Typical Voltage = 14.70 V
TP205 = 24.32 V  ------Listed Typical Voltage = 24.50 V
TP202 looks suspect?
ed12
« Reply #19 on: September 11, 2013, 06:39:17 pm »
202 and 203 look a tad off
it might cause that problem
come back from 202 and do some value testing
power off of course
ed
Gamemaster86
« Reply #20 on: September 11, 2013, 06:52:24 pm »
Sorry i'm going to need some more hand-holding here.
With the power off am I measuring resistance.
Where and how do I test backwards from that point then?
I've attached the area around TP 202 for reference.
ed12
« Reply #21 on: September 11, 2013, 08:27:56 pm »
maybe  lilshawn
can help a little here
but when u look at your schmeatic
u c the j13 and j14,unless my mind is making a south turn i think that is a horz width point?
>by boosting the b+ on tp202<
which with 200v caps should be in the 175 range
it might even make refernce to it in the manual
ed
Gamemaster86
« Reply #22 on: September 12, 2013, 02:26:59 pm »
I've reduced the B+ using VR101 so that TP202 reads 117v as it should. It however made no difference to the bent vertical lines.  :(
« Reply #23 on: September 12, 2013, 10:59:58 pm »
can you re-measure the test points now that youve tweaked the b+?
if its up where it should be we can look elsewhere, otherwise something running off tp203 is loading it down.
sorry been a bugger of a day.
Gamemaster86
« Reply #24 on: September 13, 2013, 04:41:35 am »
Sure I'll check them all again when I get home tonight.
No problem, just appreciate the help.
Gamemaster86
« Reply #25 on: September 13, 2013, 01:05:42 pm »
Ok So voltages are now as follows :
TP202 is now 117
TP203 had now reduced down to 137.8
TP204 is now at 14.72
TP205 is at 23.46
Pre B+ adjust
TP202 = 124.3
TP203 = 148.0
TP204 = 15.46
TP205 = 24.32
So TP 202 is now in line but TP203 has now reduced down even further than the recommended 152. TP204 is now as it should and TP205 is now a little lower than recommended.
« Last Edit: September 13, 2013, 01:17:23 pm by Gamemaster86 »
« Reply #26 on: September 13, 2013, 07:42:41 pm »
lets get good voltages first.
replace:
C310
C812
they are both directly related to the voltages on TP203 which is low now. I would actually recommend replacing all the 'lytics, but these are likely the cause of that voltage being low.
ed12
« Reply #27 on: September 13, 2013, 08:41:27 pm »
yes yes yes
get the voltages sorted out first
thk-u  lilshawn
ed
Gamemaster86
« Reply #28 on: September 25, 2013, 04:09:27 am »
Update:
So I have had the chassis tested and a few of the caps replaced. It appears to be fine when connected to a different tube, pic attached.
I do however feel a bit of an idiot, it appears that my monitor is one of the rarer wg 23k7401 models. I know, 23" wells gardner not usual but it does exist and seemingly only in the sammy atomiswave cab. I found someone on a different forum who took pics http://forums.arcade-museum.com/showthread.php?t=253955
THis would explain the strange yoke reading I reported in my other thread.
So now that i'm pretty sure the chassis is ok, i've also checked the coils in the yoke and could see no problems - all shiny and clean.
Any more ideas?
Gamemaster86
« Reply #29 on: September 28, 2013, 05:01:32 pm »
Any more ideas  ???
« Reply #30 on: September 28, 2013, 08:42:57 pm »
 :dunno
I got nothin'
if it works on another tube, perhaps there is a small difference in the induction value of the yoke that is throwing things off. There is a way (of which i have absolutely NO idea how to do)  to add or subtract value from certain caps to tweak the scan. You may end up blowing up the chassis or yoke though. You may have to just live with it.
get some games on that monitor and play away. You'll never notice. Trust me.
ed12
« Reply #31 on: September 28, 2013, 08:49:59 pm »
i tried to explain this to u in no unceritan terms
the restinance means squat..in the horitizal frez range
it is induntance..hence the list..please pay attenion
if u are out by 2 mill-heneres it will do that exact problem
the yoke will fire up for u but once it heats a tad >10-30< sec's will through the horz freq out,if u had a scope u can clearly see it >shift<
ed
