Author Topic: not getting 100% speed with several games  (Read 4322 times)
cyb
  • Last login:December 19, 2025, 04:07:20 pm
« on: September 03, 2013, 01:11:27 am »
Sorry if this has already been covered, but I couldn't really find a definitive answer.
First, my specs:
core 2 duo 2.2ghz
4gb ram
HD4350
winxp pro 64bit
sony pvm
I have tried several games in groovymame and almost all of them are under 100% speed.  I have attached a log for metal slug. it runs at 99.97%.  I tried it in regular MAME and it ran at 100%.
cyb
Re: not getting 100% speed with several games
« Reply #1 on: September 03, 2013, 05:46:01 pm »
It's probably my CPU. I was only getting 58% speed playing splatterhouse pce version on groovyUME.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #2 on: September 03, 2013, 06:55:23 pm »
are you running 64bit?
I've got an E8500 and everything runs fine.. though I haven't actually tested splatterhouse
cyb
« Reply #3 on: September 03, 2013, 09:55:30 pm »
yep im running 64 bit. I'm using an E4500 which is quite a bit slower than your E8500.
Sledge
« Reply #4 on: September 03, 2013, 11:20:55 pm »
Maybe see if you can source a newer CPU then, should be an easy upgrade..
cyb
« Reply #5 on: September 04, 2013, 12:20:49 am »
I might grab an E8500 off ebay...can you run 3d games such as tekken 3 at full speed with your cpu?
Sledge
« Reply #6 on: September 04, 2013, 06:49:07 am »
When I've got time to check, i'll let you know...
MonkeyJug
  • Last login:September 11, 2025, 04:54:07 pm
« Reply #7 on: September 04, 2013, 09:25:25 am »
any of you guys have the cave-hacked version and can test Deathsmiles, please?
  • Last login:February 19, 2026, 06:15:36 am
« Reply #8 on: September 07, 2013, 08:41:55 am »
Getting 99.97% speed doesn't mean a CPU issue, it's just that the achieved refresh is slightly off with respect to the theoretical speed MAME would expect, based on what it measures with the CPU clock (which you shouldn't take as God's word).
cyb
« Reply #9 on: September 07, 2013, 08:47:54 pm »
good to know Calamity thanks!
Sledge
« Reply #10 on: September 08, 2013, 03:04:57 am »
tekken 3 reports average speed of 94%, though it seems ok to me...
splatterhouse reports 99.87%
« Last Edit: September 08, 2013, 03:09:10 am by Sledge »
