Author Topic: Disc cloning, backside is twitching.  (Read 1638 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: August 27, 2013, 02:36:25 pm »
I made the mistake of buying the exact same model/size hard drive for backup purposes. Even though I checked, double checked and tripple checked the source and destination drive I'm still worried :/
Only 25 minutes to go. Still, it's only 5 months worth of work if I've done it wrong :(
Sent from Amstrad CPC464
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
Re: Disc cloning, backside is twitching.
« Reply #1 on: August 27, 2013, 03:04:31 pm »
I've used the excellent AOMI Backupper for disc cloning, it's free any works perfectly.
http://download.cnet.com/AOMEI-Backupper/3000-2242_4-75833997.html
Connorsdad
« Reply #2 on: August 27, 2013, 03:15:39 pm »
And we're done, everything is fine :)
« Reply #3 on: August 27, 2013, 03:41:22 pm »
lol.  Glad it worked out.  Now save a backup image to an external like you should have done beforehand.  ;)
  • Last login:November 26, 2025, 03:26:23 pm
« Reply #4 on: August 28, 2013, 05:56:11 pm »
good clone programs will show the serial number of the hard drive that way you are doubly sure.
i get a little paranoid too when i have only 1 existing drive of a machine and i need to re-clone it.
ive used hdclone by miray soft http://www.miray.de/home/index.html it's pretty good even for the free version.
I also have a stand alone 1-4 hard drive clone machine...it's slow as hell but works 100% of the time. Plug the original to the mater and a blank to one of the 4 interfaces and in a few hours it's done.
