Author Topic: JPAC to monitor question  (Read 1555 times)
tdarcade
  • Last login:May 22, 2014, 05:45:26 pm
« on: August 25, 2013, 03:57:22 pm »
So I am planning on using a JPAC to connect my PC to my MK cabinet. Regarding the video, my plan is to run Soft-15 and go VGA out from the PC to the JPAC. Is that all I will need to do or are there other considerations with regards to the video?  Thanks.
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
Re: JPAC to monitor question
« Reply #1 on: September 01, 2013, 01:21:31 am »
If you're turning the machine into a MAME cabinet, I would highly recommend going with CRT Emudriver and GroovyMAME.
GroovyMAME with CRT Emudriver is flat-out the best way to play arcade games on a computer.
This can get your started:
http://forum.arcadeotaku.com/viewtopic.php?f=10&t=24216
Let me know if you have questions. I can help you out.
tdarcade
« Reply #2 on: September 02, 2013, 11:33:50 pm »
Thanks I will give that a look! And yes, my plan is to play arcade games in MAME through my Mortal Kombat II cab for which I got a JPAC for to connect my PC in without having to mod the cabinet.
