Author Topic: How to change horizontal geometry  (Read 2980 times)
outrunner
  • Last login:April 01, 2024, 05:28:28 am
  • Replica Nintendo cab - done!
« on: August 25, 2013, 10:44:41 am »
Hi,
I've been successfully using groovymame with a SCART TV for a few months  :applaud: but would love to work out how to alter the H geometry so that the image isn't so over scanned on my TV.
I've read through some very complex post on this forum but can't work out exactly what I need to change in mame.ini
So far I've opened arcade osd for 384 x 240 at 60hz and by changing H front porch from 2 (2.033) to 3 (3.002) the image is placed perfectly. I assume the next step is to reflect this in a monitor spec_line?
At the moment my mame.ini has CRT_range0 to 9 all set to Auto, should I replace one of the Autos with a spec line and how do I know what spec to use?
Thanks in advance.
  • Last login:Yesterday at 05:28:27 pm
Re: How to change horizontal geometry
« Reply #1 on: August 25, 2013, 11:15:02 am »
What monitor preset are you currently using in mame.ini?
outrunner
« Reply #2 on: August 25, 2013, 03:35:11 pm »
Hi Calamity, I was hoping you'd reply  :)
The mame.ini has what I assume is the default preset of generic_15
« Reply #3 on: August 25, 2013, 04:09:15 pm »
Hi outrunner,
Try the following, in mame.ini
monitor custom
crt_range0 15625-15750, 49.50-65.00, 3.002, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576
outrunner
« Reply #4 on: August 25, 2013, 05:49:17 pm »
Yep that did the trick :applaud:
Thanks for the support Calamity - think it's about time I made a donation. If it's not too much bother please can you post the link to donate, can't remember where to find it?
« Reply #5 on: August 27, 2013, 02:47:51 pm »
Hi outrunner,
I'm glad that it worked. There are donation links in https://code.google.com/p/groovyarcade/
