Author Topic: Buggy background music workaround  (Read 3551 times)
capitaineflam25
  • Last login:December 12, 2014, 12:03:52 pm
« on: August 25, 2013, 07:32:14 am »
Hi,
The built in background music feature is too unstable for my needs:
random crashes or stops, difficulties with some characters (like "'") in the mp3s, non wanted stop when screensaver starts, issue with the fade in/out feature.
So i tried to do something different with a lightweight external player and i'm happy with the result.
So you can install Foobar 2000 (tested with 1.29, you can download it on http://www.foobar2000.org/download), and prepare a playlist.
If you like it, you can select the "Shuffle" option, which is a enhanced random feature, to avoid track reapeat.
I have also activated Fade In/Out for a smoother experience, autogain and always reduce in tray feature.
Then you can create a bat file to both start Foobar and Mala:
Code: [Select]
  @echo off
  start foobar2000.exe /play /hide
  start MaLa.exe
And a second bat file which you will launch from MaLa instead of mame.exe:
Code: [Select]
  @echo off
  foobar2000.exe  /pause
  mame.exe %1 %2 %3 %4 %5 %6
Enjoy your rock solid background player with fade/in out feature  ;D
« Last Edit: August 25, 2013, 07:34:32 am by capitaineflam25 »
loadman
  • Moderator
    • MaLa
Re: Buggy background music workaround
« Reply #1 on: November 30, 2013, 03:54:49 am »
Nice,
But I must fix this....
Remind me
gemini6920@hotmail.com
  • Last login:July 26, 2016, 06:29:56 pm
« Reply #2 on: April 10, 2014, 12:02:53 am »
Loadman,
Have you worked on fixing the background music issue? I love Mala, but really want background music to play automatically when i start Mala,   Saw this post that said remind you to fix this, so here is your reminder.  Does anyone have any tips on how to make this work?
