Author Topic: Mame conversion - need tool advice (routers?)  (Read 2421 times)
mizzouman6
  • Last login:August 23, 2013, 09:01:22 pm
« on: August 23, 2013, 03:19:04 pm »
I picked up an old Tekken cabinet and start stripping it down to replace the vinyl and t-molding.  As I tore the first piece of molding off the control panel I discovered that the old molding wasn't t-molding, but just a piece of plastic molding glued on.  So I need some advice on which tool to purchase to cut the t-molding channel on an already assembled cabinet.
From what I'm reading, I need some kind or router or Dremel that has a guide to butt up against the side to create an uniform cut depth and stay straight against the edge to keep the channel centered.  The wood is 3/4" plywood.
Can someone direct me to some tools that will help get me back on track with this project?  I don't have a Dremel or router right now.  Just some hand tools and cordless drill.
Thanks.
Unstupid
Re: Mame conversion - need tool advice (routers?)
« Reply #1 on: August 23, 2013, 04:01:02 pm »
Router Bit:
http://www.amazon.com/Freud-63-100-16-Inch-Cutter-4-Inch/dp/B0002TUCRA
Router (cheap):
http://www.amazon.com/SKIL-1810-Fixed-Base-Router/dp/B0000C6DXX
Router (better):
http://www.amazon.com/Bosch-1617EVS-2-1-Variable-Speed-Router/dp/B00004TKHV
If you go with the better router then look for a similar router bit but with a 1/2" shank.  Don't use a dremel!
« Last Edit: August 23, 2013, 04:03:06 pm by Unstupid »
  • Last login:Today at 08:45:26 am
« Reply #2 on: August 23, 2013, 04:08:23 pm »
Welcome aboard, Mizzouman6.
A Dremel won't have the power (or take the bit) to cut a t-molding slot.
Check out this thread and this one.
« Last Edit: August 23, 2013, 04:11:52 pm by PL1 »
mizzouman6
« Reply #3 on: August 23, 2013, 07:50:17 pm »
Thanks for the tips.  Forgive my ignorance, but with just the router and bit, will I be able to control the depth of the cut and align the router to make sure it stays centered in the wood?  Would I need something like the plunge router attachment, referencing the router posted by Unstupid?
Unstupid
« Reply #4 on: August 23, 2013, 08:36:57 pm »
You don't need a plunge router.  You will be able to set your depth of the slot cut on the router.  check out this video for basics:
mizzouman6
« Reply #5 on: August 23, 2013, 09:01:22 pm »
Awesome.  Thanks for the video link.  Watching it now.
« Reply #6 on: August 23, 2013, 09:07:33 pm »
Both models Unstupid posted have a micro-fine depth adjustment. (highly desirable feature)
Ensure the bit is tightly secured in the collet before you begin cutting and check regularly to ensure it hasn't loosened.
Do test cuts on a scrap piece of MDF to align the depth before you start on the actual cab parts.
You can do almost everything you need to do with either a fixed base or plunge router.
Plunge routers can be locked in the down position, though sometimes that doesn't work so good for t-molding bits.   :o
Some routers even have swappable fixed and plunge bases like this one.
BTW the video above shows him cutting clockwise -- he should be cutting counter-clockwise.   :banghead:
« Last Edit: August 23, 2013, 09:12:31 pm by PL1 »
