November 29, 2025, 02:08:09 pm
On any two terminal button, it doesn't matter which terminal you connect to ground and which you connect to the encoder.When you press the button, the switch closes and is electrically the same as a piece of wire.Scott
Thank you Scott. You are always a plethora of information. And what don't you like about the buttons kuehnau? Do they not respond well enough?
