Author Topic: How do I get the knob off of a Happ Super Joystick?  (Read 1356 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« on: November 16, 2003, 08:52:18 pm »
I am trying to use the Super Base &  Lever to mount a pair of Tron handles to...but the super knob is way too big to fit inside.
I am considering sanding the plastic off of the knob, but if anyone has a better idea, I'd love to hear it.
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
  • Last login:February 28, 2026, 04:55:22 pm
Re:How do I get the knob off of a Happ Super Joystick?
« Reply #1 on: November 16, 2003, 11:48:35 pm »
I have a couple of Happ's Supers...
After some inspection, I think you will need to sand/saw them off.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: November 17, 2003, 04:27:05 am »
For my competition hack, I used some metal rods (hollow) I got from my local ace hardware.  Hollow so I could run the wires down into the CP.  Basically the same as Oscar Controls hack.
Robin
Knowledge is Power
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #3 on: November 17, 2003, 10:07:49 am »
Yeha, you're much better off fabricating a new shaft. Much simpler. Besides, how do you think you're going to run the wires for your Tron stick through a solid shaft?  :o
If you build a frankenpanel, chances are I don't care for you as a person.
soslo
  • The Governator
« Reply #4 on: November 17, 2003, 10:31:15 am »
Well, I sanded the knobs down...that sucked. Good thing I was wearing my respirator! Those things are resilient.
At any rate, the Tron handles base opening is larger than the joystick shaft, so the wires can run down next to the shaft.
I then drilled a hole through the base to pass the wires through. This solution works, but is not as clean as a hollow shaft...so I'll look into that route. I just need to figure out where to get hollow stock the same saize as joystick shaft. Off to OSH I go...
