Author Topic: limit horizontal range to 16.1 khz?  (Read 2009 times)
pakoman
  • Last login:November 05, 2024, 08:36:26 am
« on: August 19, 2013, 01:16:06 pm »
Hi.
I'm using GroovyUME with scart PAL tvs, and I'd like to limit the horizontal range to 16.1 khz becouse modelines over that are problematic with my setup. I'd like to emulate a wide range of systems from PAL amiga and Amstrad GX4000 to other using some high res interlaced resolutions as faithfully as the original in a resolution basis.
For instance Turbo grafx 16 goes out of sync as it tryes a 16.6 khz resolution.
I don't know if I need to modify any other value. Is there any generic CRT monitor settings for a setup like this, a plain scart tv bought in Spain? Or a simple way to limit horizontal frequency to 16.1?
Thanks.
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
Re: limit horizontal range to 16.1 khz?
« Reply #1 on: August 20, 2013, 11:02:32 am »
Hi pakoman,
You just need to create a custom crt_range, limiting the horizontal frequency range to whatever you want:
monitor custom
crt_range0 15625-16100, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 192, 288, 448, 576
Here I've set the highest value to 16.1 kHz.
Steps to create a log:
pakoman
« Reply #2 on: August 20, 2013, 04:38:48 pm »
Thanks, I didn't think it was so easy :)
