Author Topic: Mamewah layout problem cfg posted..  (Read 995 times)
snowdogg187
  • Last login:June 16, 2008, 12:08:18 am
« on: November 16, 2003, 06:49:46 pm »
When I load mr saltys 640x480 layout it shows everything except the backround picture. It just shows it as a gray background.
and I did point the layout.cfg to point where the layout-main.jpg background is.
any pointers?
Re:Mamewah layout problem cfg posted..
« Reply #1 on: November 16, 2003, 07:18:54 pm »
I expect the .LAY file was created using an earlier version of MW/Layout Designer...
The image must be within the same folder as the .LAY, and called main.jpg (I changed this slightly a few versions ago).  FYI the filename in the .LAY file actually does nothing, except when opening in the Layout Designer.
snowdogg187
« Reply #2 on: November 16, 2003, 07:36:09 pm »
tnx minwah for the quick fix!!
