Author Topic: PC in case or with out? (solved)  (Read 2605 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: August 17, 2013, 06:11:44 pm »
was planing to use a laptop but i just got a cpu hope is good enought for MAME . The cuestion is with case or with out? thanks
• ASUS P5QPL-AM Micro ATX motherboard
•Intel Core @ Duo 7400
•4GB crucial DDR2 800 RAM
•500 GB Western Digital SATA Hard Drive (7200rpm-16mb buffer)
•Integrated intel GMA X4500 Graphics
•Windows 7
« Last Edit: August 17, 2013, 09:45:01 pm by Caparo8bit »
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
Re: PC in case or with out?
« Reply #1 on: August 17, 2013, 07:24:06 pm »
Caparo8bit
  • Hyperspin/Maximus
« Reply #2 on: August 17, 2013, 09:45:57 pm »
Caparo8bit
  • Hyperspin/Maximus
Re: PC in case or with out? (solved)
« Reply #3 on: August 18, 2013, 02:35:55 pm »
Love the fan can change speed L.M.H    ( still working on cables)
BobA
  • What Me Worry?
« Reply #4 on: August 18, 2013, 08:24:26 pm »
I just build bartops so the MB has to be mounted in the cab due to a lack of room.  I just make sure there is a fan at the top rear of the cab blowing heat out and make sure there is a way for the outside air to enter the cab.  I always have a power supply at the bottom rear of the cab so I reverse the fan so it blows air into the cab not out as a PC power supply usually does.
Caparo8bit
  • Hyperspin/Maximus
« Reply #5 on: August 18, 2013, 08:43:35 pm »
computer have 2 fans arcade 1 and I'm adding one on top the blows hot air out   how do you revers fan circulation?
BobA
  • What Me Worry?
« Reply #6 on: August 18, 2013, 10:24:39 pm »
I reverse the flow from out of the PS to into the PS and out to the cab by physically turning the fan around that is in the PS.  You open the PS remove the 4 screws that hold the fan and flip the fan around and screw it back into place.  There is always enough wire on the fan to do this.
Caparo8bit
  • Hyperspin/Maximus
« Reply #7 on: August 18, 2013, 11:13:37 pm »
here is a pic of the current fans hit me up with the best air circulation setup
