Author Topic: stand alone control panel  (Read 1236 times)
mado21
  • Last login:March 04, 2016, 06:07:11 pm
  • I want to Build My Own Arcade Controls!!
« on: August 17, 2013, 01:02:14 pm »
hi im going to have a go at making a control panel to play mame on my desktop computer.before i try to make a full size cab
what is minimum number of buttons i would need?
im thinking of 1-joystick,4-action buttons,1-player start,1- credit button
anything else i might need?
im going to use this encoder http://www.ebay.co.uk/itm/New-Zero-Delay-Arcade-USB-Encoder-PC-to-Joystick-for-5pin-Sanwa-Type-Push-button-/171060862728?pt=LH_DefaultDomain_0&hash=item27d4059f08
JDFan
Re: stand alone control panel
« Reply #1 on: August 17, 2013, 02:09:35 pm »
Depends on the games you plan to play -- For example if you want to play Robotron, Smash TV and similar you would want 2 joysticks - for fighting games like Street Fighter etc. probably 6 buttons rather than 4. THen there are the specialized games that use Spinners or Trackballs. So best to decide what games you are really wanting and then design the CP layout to fit those games.
For Example I like to play Robotron and Smash TV so built my CP with 2 joysticks and also do use some of the fighting games so also included 6 buttons and added 6 other buttons ( 1&2 Player Start and Coin, Pause, Exit) Also using a ZD encoder so wired it so that the 2nd joystick and player buttons 3-6 share the same input since it is limited to 16 inputs ( 4 for joystick 1, 4 for joystick 2 shared with 4 buttons, 2 unshared buttons, and 6 Admin buttons = 16 inputs) and no games use both the 3-6 buttons and 2 joysticks so those were the easiest to wire as shared inputs !)
I purchased a set of joysticks and 14 buttons from Ebay for $33 + $10 express shipping which along with the $11 ZD encoder was all I needed for the setup including 1 button I used for the on\off switch on the back and left 1 extra button not used so about $50 total investment.
EDIT : Be sure to order the correct type of ZD encoder for the buttons\joystick you are getting -- I notice the one you posted is designed for a Japanese Joystick that uses 5 wires and also the smaller Japanese quick disconnects for the buttons rather than the Happ type Joysticks and buttons -- so be sure to get the type that fits the buttons you are getting !!
Here is a pic of the layout I used for my Bartop :
« Last Edit: August 17, 2013, 02:25:18 pm by JDFan »
mado21
« Reply #2 on: August 17, 2013, 03:39:41 pm »
thanks for the reply,i dont play fighting games ,so i figured that 4 buttons would be ok .
it was the admin buttons i was thinking about.this is more of a test build to see if my skills are up to building a cab
thanks
JDFan
« Reply #3 on: August 17, 2013, 04:17:04 pm »
Then 4 should be plenty -- plus if you do find you need more later you can always just remake the top panel later. That's the good part of making a stand alone CP first as a trial, you can test things out and at the same time get an idea of the things you'll want on the build later.
  • Last login:Today at 04:33:28 pm
« Reply #4 on: August 17, 2013, 06:06:35 pm »
Consider having Exit and Pause buttons.
Since this isn't for a dedicated cab, you may also want to consider a Menu (Tab) button and maybe even an Enter.
If you need to convert the ZD Encoder's HID gamepad button presses into keystrokes, look into joy2key(JoyToKey?) or xpadder.
JDFan
« Reply #5 on: August 17, 2013, 06:30:27 pm »
One other thing to keep in mind is since you are going to be using it on your desktop -- you will have the computer keyboard right next to you so really all you need are the game play buttons since you could just set up the admin functions to use the keyboard (maybe just a pause button to stop the game while you get the keyboard out.)
mado21
« Reply #6 on: August 17, 2013, 10:57:45 pm »
thanks for all your input guys,it been a great help
mark
