Author Topic: 6 buttons  (Read 3445 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
6 buttons
« on: August 15, 2013, 08:23:06 pm »
do we really need 6 buttons per player???????????   medium and high punch/kick  (4buttons) will b enough? ::)
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
Re: 6 buttons
« Reply #1 on: August 15, 2013, 08:48:15 pm »
Some people run 6, some run 7. If you run 7, you can use the bottom 4 for neo geo.
Sent from my SGH-T989 using Tapatalk 2
Caparo8bit
  • Hyperspin/Maximus
Re: 6 buttons
« Reply #2 on: August 15, 2013, 08:56:10 pm »
whats with neo geo ( noob)
Re: 6 buttons
« Reply #3 on: August 15, 2013, 10:03:12 pm »
Neo geo used 4 buttons and people will do the "street fighter six" and add a 7th button to the bottom left of the bottom row, which makes a convincing NeoGeo layout. Also makes a good run button for the MKs that used it.
mgb
  • North East, US
6 buttons
« Reply #4 on: August 15, 2013, 10:16:12 pm »
I'm not quite sure I understand your question but if you're gonna play fighters like the street fighter series, you're gonna need 6 buttons for the full effect though I guess you can use 4 and only have medium and hard punch and kick but that would affect some special moves.
  I can only fit 4 buttons per player on my cab so I just resolve to playing neo geo fighters.
   If you don't know what neo geo is, I'd suggest some googling. Check out www.hardmvs.com
ron310
  • Last login:July 18, 2016, 06:30:13 pm
6 buttons
« Reply #5 on: August 16, 2013, 08:26:11 pm »
I started my bartop as a 4 button neo geo type layout.
I then added 3 more buttons about a year later to play some capcom fighters.
I was going to eliminate the top right button altogether, but I like using it for neo geo games, so it stayed.
The bottom left button and the top right are wired together, so they both act as "button 4" depending on what I'm playing.
nitz
  • Last login:November 24, 2015, 07:57:29 pm
Re: 6 buttons
« Reply #6 on: August 17, 2013, 02:46:17 am »
If I had only 4 buttons and wanted to play Street Fighter, I would have them set up as weak and medium punch and kick, and when you press both weak and medium punch (or kick) simultaneously you get hard punch or kick. I've never tried it but I think that would be fairly intuitive.
Re: 6 buttons
« Reply #7 on: August 17, 2013, 04:21:04 pm »
might work for the regular SFs, but would make playing some of the VS games a nightmare or at least harder.
mgb
  • North East, US
6 buttons
« Reply #8 on: August 18, 2013, 10:27:35 pm »
Yeah that makes better sense probably.
dgame
  • I am no Jedi
Re: 6 buttons
« Reply #9 on: August 19, 2013, 01:12:33 pm »
To play SF2 properly you need all 6 buttons.
1. The light punch cancels dash attacks (Ken vs Blanka)
2. The medium dragon punch goes through fireballs (Ken vs Ryu)
These are just two examples but the point is that light and medium attacks are not interchangeable and both are needed in different situations with various players.
BUT if I was limited to just four buttons it would be the lights and hards that stay.
Caparo8bit
  • Hyperspin/Maximus
Re: 6 buttons
« Reply #10 on: August 19, 2013, 09:45:56 pm »
yeah im adding 6 per player (2player panel) i dont know if i can feet a 4 player . Ne ways i only have a j-pac and not planing to buy i-pac so  start  will  b the shitf to control frontend
and im looking for ideas on my panel this is my size
