Author Topic: Arcade/PC items for sale (Cheap desktops/laptops - Windows 10 ready)  (Read 153763 times)
Re: Arcade/PC items for sale
« Reply #320 on: May 15, 2015, 02:38:16 pm »
they are M91s
Demon-Seed
    • DemonCade (WORKING URL!)
« Reply #321 on: May 16, 2015, 06:29:03 am »
I am enjoying my modded too however some games lag ie) sega Naomi. I also would love to play the new mk on it so I am wondering what video cards are recommended? I noticed there has been talk of upgrading I just want to e sure the card works
Jim
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #322 on: May 16, 2015, 08:16:05 am »
Which Demul are you using?  5.8 struggles on my modder but 5.7 seems to work well.
magus90
  • Last login:July 23, 2019, 05:05:40 pm
  • New to MAME, can't wait to get my rig built
« Reply #323 on: May 16, 2015, 02:25:59 pm »
Jim
You need a low profile card.
I bought the 1gb GT 730 because i like nvidia. But there is a better AMD card that will work  AMD R7 250 low profile. Its more expensive though.
http://www.amazon.com/XFX-1050MHz-Profile-Brackets-R7-250A-CLF4/dp/B00H5DJDL2/ref=sr_1_7?ie=UTF8&qid=1431800678&sr=8-7&keywords=r7+250
http://www.amazon.com/PNY-GeForce-GDDR5-Graphics-VCGGT7301D5LXPB/dp/B00KYCTCZ8/ref=sr_1_1?ie=UTF8&qid=1431800710&sr=8-1&keywords=pny+gt+730
Demon-Seed
« Reply #324 on: May 16, 2015, 02:33:27 pm »
Hey
From what I read mk x requires a 2gb card?
Jim
DarthMarino
« Reply #325 on: May 16, 2015, 02:51:25 pm »
I put a Zotac Geforce GT 610 2GB Synergy Edition in mine:
http://www.zotac.com/en/products/graphics-cards/geforce-600-series/gt-610/product/gt-610/detail/geforce-gt-610-synergy-edition-2gb.html
It's low profile but I had to put a 400w power supply in that fit right into the case.
Demon-Seed
« Reply #326 on: May 19, 2015, 09:56:56 am »
is there any that do not need a new power supply?
« Reply #327 on: May 19, 2015, 10:34:53 am »
just look up any slim PCIe that doesnt have additional power hook ups that run on a 250W system
Santo8742
  • Last login:September 11, 2015, 06:48:39 pm
« Reply #328 on: May 20, 2015, 10:10:20 pm »
So I bought this video card for the modder system and can't get it to work: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150713. I went into the bios and changed the video to auto which is supposed to boot video from pci-e first. Then I put the video card in. But when I put the video card in and turn on the computer, I get no video even before windows boots (i.e. bios startup) and the keyboard and mouse don't seem to be detected. I take the video card out and everything boots fine with the video connected to the onboard again. Any ideas why it is doing this and is there a solution that anyone knows about? I have tried it with the bios set to both auto and pge (which is the pci-e setting) and get the same results.
Are you using the power supply it came with?  The Newegg page says it requires 400w minimum.
No. I bought a 500 watt power supply. This one: http://www.amazon.com/gp/product/B00H33SFJU/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
I should note, all fans come on when I boot with the video card in it including the fan on the video card itself. There are no system error beeps. I also tried updating the system bios to see if that helped. Still no video or peripherals working when video card is connected.
Edit: So I tested the video card in another machine and it was doing the same thing. I guess it's bad since it didn't work in two machines. I'll try to exchange at new egg.
Update, finally got a replacement card and it's doing the same exact thing. First card was from New Egg. I sent it back for a refund and bought it on Amazon, so it's not like a bad batch or anything. Any idea why I would be having this problem? Is there a driver I need to install to use the pcie port or something?
« Reply #329 on: May 21, 2015, 07:28:45 am »
Did you test the new video card in another machine as well?
Santo8742
« Reply #330 on: May 21, 2015, 07:22:52 pm »
I tested in my main machine, which is a different machine than the other machine I tested in on the last card, and I got a picture, so the card works. Next, I disconnected my large power supply from my main computer and hooked it up to the machine I'm trying to use the card in and got the same results as before, so it's not a power supply issue. I made sure the video in the bios was set to pce which is what it said pci-e should be. So, I guess I've narrowed it down to the board not functioning correctly or the card is incompatible. Which would seem odd because the card was recommended by others in this thread. Don't think the board is malfunctioning because that first card didn't work in that other machine either. Any suggestions? Why would the card be incompatible if that is the case? It's pci-e 3.0, but I've read that cards are backwards compatible with older pci-e slots, so that shouldn't be an issue.
Santo8742
« Reply #331 on: May 22, 2015, 09:04:07 am »
Jim
Are you positive the AMD card works? I'd like to get confirmation from someone that it's compatible. Otherwise I'll try to return it and buy a different one.
Edit: Decided I'm going with a different one. Can't get it to work for anything. Anyone looking, I'd recommend avoiding the R7-250A-CLF4 for this computer. I went with this one that an user above is using: http://www.zotac.com/en/products/graphics-cards/geforce-600-series/gt-610/product/gt-610/detail/geforce-gt-610-synergy-edition-2gb.html. Should be in Sunday. Hope it works.
« Last Edit: May 22, 2015, 09:57:15 am by Santo8742 »
Santo8742
« Reply #332 on: May 24, 2015, 03:22:41 pm »
Jim
New card came in today. I put it in the computer and it fired right up. So, I'd say definitely avoid the R7-250A-CLF4 for this computer. It must not be compatible with the computer.
« Reply #333 on: May 24, 2015, 10:01:19 pm »
I'll always take nvidia over ati
dluusional
  • Last login:February 09, 2019, 06:13:28 pm
« Reply #334 on: May 25, 2015, 11:18:44 am »
I bought this card
http://www.gigabyte.com/products/product-page.aspx?pid=4792#ov
will this fit inside the pc's? or will only low profile cards fit?
Thank you,
DarthMarino
« Reply #335 on: May 25, 2015, 12:05:27 pm »
I bought this card
Thank you,
You'll need a low profile card for the case it comes in.
Peabo
  • Pinball junkie
    • Virtual Pinball Build
« Reply #336 on: May 27, 2015, 07:57:46 pm »
Received a pc today and it booted right up, thanks!
JimmyU
  • Last login:December 16, 2025, 09:26:22 pm
  • I believe I can fly!
« Reply #337 on: May 27, 2015, 08:51:34 pm »
If somebody has the the new MAME rom set, could you run Golden Tee Fore on the modder system?
Thanks!!
DarthMarino
« Reply #338 on: May 27, 2015, 08:58:09 pm »
Thanks!!
I've been playing Fore for the past few weeks on the modder (first time I compiled my own MAME because I couldn't wait for this game!).  As we've discovered, my modder is actually slightly faster than everyone elses but I think they'll all play it just fine.  One important note: the game will struggle pretty often on the default settings.  Change the dipswitch to low resolution and it should run near 100% at all times.  You'll get an occasional audio hiccup here and there especially if you end up in the woods, but it's very playable.
  • Last login:Yesterday at 11:30:00 pm
« Reply #339 on: May 27, 2015, 09:39:36 pm »
Wait a second... they actually emulated Golden Tee Fore in MAME?  When did this happen???
JimmyU
« Reply #340 on: May 27, 2015, 09:43:12 pm »
In MAME 0.162 which was released yesterday. It might become the new Gauntlet Legends in terms of measuring your system.
JimmyU
« Reply #341 on: May 27, 2015, 09:44:29 pm »
Thanks!!
Thanks for the info. :cheers:
« Reply #342 on: May 27, 2015, 11:49:44 pm »
 :dizzy:
DarthMarino
« Reply #343 on: May 28, 2015, 08:54:08 am »
If you're looking to get all the courses, just get the first game and Golden Tee Fore Complete.  Complete has everything except two 9 hole courses from the first game (Royal Bannockburn and Rolling Acres).  Those are the only 2 games I test on the Modder but I assume they all work fine.
Another tip, make sure you press T to go into test mode after it boots up to adjust the sound.  It defaults at basically 0. I also cleared out all the records and leaderboards since some of the computer scores are almost impossible to beat.
« Last Edit: May 28, 2015, 10:48:03 am by DarthMarino »
« Reply #344 on: May 29, 2015, 11:08:33 am »
Yeap, just bought another, 10th one I think.
  • Last login:Yesterday at 02:02:09 am
« Reply #345 on: May 29, 2015, 11:17:40 am »
Make sure he updates your punch card... the next one is free.  :cheers:
« Reply #346 on: May 29, 2015, 12:55:55 pm »
Does it run Golden Tee Complete 100%?
« Reply #347 on: May 29, 2015, 01:23:16 pm »
You have to link all 10 together to form a supercomputer, and even at that it only runs as 98.7%.
« Reply #348 on: May 29, 2015, 01:25:17 pm »
Do a search Noob
DarthMarino
« Reply #349 on: May 30, 2015, 11:57:22 pm »
Here are the Golden Tee Fore! games running on my Modder system:
The dip is set to low res.
« Reply #350 on: June 04, 2015, 10:00:25 am »
so I didnt PM him, email him, or anything extra. Just paypalled him for the system and I got a tracking number 2 days later. Just FYI
SNAAKE
  • Trade Count: (+29)
« Reply #351 on: June 04, 2015, 12:11:04 pm »
nothing will replace gauntlet legends...NOTHING :burgerking:
mrangrygrandpa
  • Last login:April 24, 2022, 10:56:23 am
« Reply #352 on: June 08, 2015, 09:51:55 am »
Has anyone tried out any games on the "modder" system with the Dolphin emulator or steam? I would assume I'd need one of the gfx cards that was mentioned previously, but I just thought I'd check.
Thanks to those who have already listed out tested games in the thread. It's been super helpful!
DarthMarino
« Reply #353 on: June 08, 2015, 11:35:56 am »
I've tried a few but the performance really depends on the game.  Mario Galaxy runs.....OK but can be sluggish at times. Not really good enough for me to play through. I'll have to stick with the SD version on Wii for now.  Mid-range games run pretty well for the most part. The Wiiware Target Toss Pro games worked perfectly for me on 1080P.
pompetti
  • Last login:December 04, 2018, 08:42:45 am
« Reply #354 on: June 20, 2015, 10:31:54 am »
What's the OPs Paypal? I'm too new to send pms
nitrogen_widget
« Reply #355 on: June 24, 2015, 11:32:44 am »
I think i'm going to end up using my modder for Steam on the TV for the kids.
Mostly castle crashers & Lego games.
From what I've read the Nvidia GTX 720 should work with the stock PSU no problem.
it's a 720p TV so I think it should be good enough to run the games smoothly and look at least as good as the kids Wii.
anyone know of a better card that works with stock psu?
ramos8414
  • Last login:January 09, 2019, 08:27:24 pm
« Reply #356 on: June 24, 2015, 04:00:25 pm »
The R7 250 is faster and it should work with the stock PSU.
nitrogen_widget
« Reply #357 on: June 24, 2015, 04:40:44 pm »
I purposefully didn't mention that card because Santo a few posts back tried two of them and couldn't get the PC to boot.
Someone is using a GTX 730 but I need to get the GDDR version otherwise the 720 appears to be faster.
730 gddr is about $80 while 720 is $60.
not sure i'll get that much of a performance increase since performance is the wrong term to use when referencing these low power cards. :)
ramos8414
« Reply #358 on: June 25, 2015, 12:55:50 am »
I would get the GDDR5 GT 730, its only $65 on newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133542&cm_re=gt_730-_-14-133-542-_-Product
nitrogen_widget
« Reply #359 on: June 25, 2015, 12:03:45 pm »
good find! And good price Thanks.
these cards are damn annoying because it appears there are two different gpu's in the 730's.
